Toshiba Sattelite pro Laptop, when I power up lights come on and then it powers down?
When I power up lights come on and then it powers down? Tired plugging and unplugging power lead, which works as power light goes on and off tried power down on the power button and then powering back on tried taking the battery out and refitting then starting again. the processer goes through a cycle and then powers off each time, with nothing on the screen? I have hooked up another monitor and used the functon keys to link to that monitor but nothing
  • 7,627 Answers
  • 324 Answers
SOURCE: Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Posted on Nov 09, 2007
  • 987 Answers
SOURCE: Toshiba laptop will not boot - black screen
The RAM might have problem...
Posted on Jun 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
rohithdol567
SOURCE: My compaq laptop will not turn on. With the power
if u know repairing laptop ,u just open the back case of that and remove full outlet & see where the screen display chip is attached to the motherboard,if u see that u just remove the screws and clean it, afterwords add some heat sink compound to that and attach with screws,this is the best best solution & do it carefully
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: my laptop won't power on (EliteGroup G320 PC Notebook)
Sounds like the infamous electrolytic capacitor plague (see http://en.wikipedia.org/wiki/Capacitor_plague -- also read the discussion page)
In the early years of this century chinese spys stole a formula for novel electrolyte from a leading Japanese chemical company but unfortunately they only copied page 1 of the two-page recipe. The incomplete electrolyte went into many millions of capacitors reducing their life span dramatically. I understand these capacitors were made until 2004. That's about the time the G320 was manufactured, at least mine.
I opened and disassembled everything, I saw some "swollen" 1500uF/6.3V capacitors, replaced them and the G320 would start again.
This may sound easier than it was, however. I live in a country where computers aren't made no more and spare parts are hard to find. The G320 has 4 of the above caps in upright position and 4 placed horizontally. I could only get some larger types that do fit horizontally but not vertically. Thus I had to replace a bad vertical one by one of the remaining good horizontal ones and then replace the horizontal ones by the bigger ones.
Warning!
If you re-assemble your G320 make sure you use the shortest 3 screws for the the points where the upper cover is fastened to the metal sheet frame that presses the cpu against the heat sink. If you use a longer screw (which I did) you may experience that a destroyed 4x56 ohms resistor network chip on the mainboard can also be hard to be relaced in non computer producing countries.
Mittwoch
Posted on Nov 14, 2009
Toshiba Sattelite PRO L300 telling me checking file system C one of disks needs to be checked However it then says an error has occured and won't leave this screen !
Press F8 and choose command prompt.You may have to use a boot disc if you can't get c prompt.
Type cmd ENTER. From the Command Prompt type chkdsk /r/f ENTER. R and F are redundant for repair and fix, but does not hurt.
Oct 29, 2012 | Toshiba Satellite Pro L300 Notebook
Dead toshiba satellite laptop
If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 01, 2012 | Toshiba Sattelite A105-S2071 Notebook
I have a toshiba l640 sattelite that does not turn onj with battery or power pac
Remove main battery and power on, if no! check the power supply/charger for correct voltage, if okay! the dc jack in the laptop is often problem. The laptop at this stage will need to be dis-assembled down to the motherboard I recommend a pro for this section because of the complexity and soldering skills required.
Mar 28, 2012 | Toshiba Computers & Internet
Hi computer will not stay on at all ... before this power would last for 20 mins or so then shut down , no problem with over heating or not charging , any ideas many thanks jan
Hi there it appears if the lights turn off on the front of the laptop and its not warm the the charge/power management chip is going bad and must be replaced I'm having the same problem it might also be ur charger as well
Jan 18, 2011 | Toshiba Sattelite® Pro A200 PC Desktop
How to remove toshiba a200 model the password after power on?
Press the appropriate key to enter BIOS setup.
Enter the current password, to allow you to access BIOS setup.
Then, set a new password.
The password exists to prevent a thief in possession of your laptop from using the stolen computer.
Find your original bill-of-sale, and telephone Toshiba, and they will help the registered owner in resetting the password.
Jul 22, 2010 | Toshiba Sattelite® Pro A200 PC Desktop
My toshiba laptop is not responding only orange light flashes
Hello try pushing the power buttom again as most laptops go into a sleep mode when lefton and no one has touch them for a few minutes . If that doesn't work, maybe it's defective and such be brough back to the supplier for replacement or refund ( don't forget the receipt )
Mar 07, 2010 | Toshiba Sattelite® Pro A200 PC Desktop
My laptop turns on then the screen goes black and nothing happens
Try taking battery out and holding power button for 30 seconds or so,,some times a static build up..
Feb 07, 2010 | Toshiba Sattelite® Pro A200 PC Desktop
Wants to reload toshiba power saver on sattelite M30 download
if you have vista.... or xp for that matter it's in the control panel... power options
Robert
Jan 02, 2009 | Toshiba Computers & Internet
Toshiba sattelite a200 won't turn on
This is a common problem for toshiba laptops, unfortunatly. Usually when this happens either your laptop charger is fried, or you will need to replace the actual laptop plug inside the laptop.
Oct 31, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
