GA-7VX memory error
November 29, 2012 A Kingston 512MB/PC133CL2 memory module inserted into slot 1 or slot 2 of a Gigabyte GA-7VX mainboard passes test #8 of Memtest86+ v4.20. Another identical memory module inserted into slot 1 or slot 2 passes this test, too. However, if both memory modules are inserted into slots 1 and 2 of the mainboard giving 1024MB of memory, test #8 reveals a great number of memory errors. How can one overcome this error? Thanks and best regards.
  • 2 more comments
  • Henry Dombrowsky Nov 30, 2012
    The memory is Kingston KVR133X64C2/512
    In the BIOS option SDRAM CAS# Latency is set to 2
  • Henry Dombrowsky Dec 02, 2012
    The two memory modules are Kingston ValueRAM 64M x 64-bit (512MB) CL2 SDRAM (Synchronous DRAM) PC133 DIMM module. The components on this module include sixteen 32M x 8-bit (8M x 8-bit x 4 Bank) PC133 SDRAM in TSOP packages. This 168-pin DIMM uses gold contact fingers and requires +3.3V.
  • joecoolvette
    joecoolvette Dec 03, 2012
    Sorry, didn't mean to be so long with a reply. (Family business) Yes. I checked that ram memory out on Kingston's website, http://www.valueram.com/datasheets/KVR13... CL2 is OK. 64Meg X 64 bit chip configuartion is OK. 133MHz frequency rate ram memory, uses the JEDEC standard of 3.3 Volts for SDR Sdram ram memory. AND, from further looking the motherboard supports ECC ram memory. Question is; WHY would anyone want to use slow SERVER computer ECC ram memory, on a standard computer? You WOULDN'T. Error Correcting Control. Also known as Error Checking Control. Looks at least twice over the data (Information), to MAKE SURE it has it right. It is Server computer ram memory. Don't know if the Kingston KVR133X64C2/512, is.
  • Computers & ... Master
  • 5,660 Answers
Kingston manufacturer code on side of Ram Memory module, please. Need to know if it's compatible. Post back in a Comment.
http://hothardware.com/Reviews/Gigabyte-GA7VX-Slot-A--VIA-KX133/
Should be;
SDR Sdram at 133MegaHertz. (PC133)
LOW-density, unbuffered, Non-ECC, 3.3 Volt, 64Meg X 64 chip configuration, Cas Latency of 3.
Suspect Ram Memory you bought as the problem; especially if it is ECC, high-density, SERVER computer ram memory, sold on Eb** all the time.
Getting rid of surplus inventory, that NOBODY really wants.
Awaiting reply;
Regards,
joecoolvette
Posted on Nov 30, 2012
5 Suggested Answers
swufabuda
  • 219 Answers
SOURCE: 775i65G does not work when two 1GB DDR400 are installed.
I would venture to say one of the memory modules you have is bad..
Posted on Feb 01, 2009
  • 2692 Answers
SOURCE: Simply upgrade to more memory
Your board and computer are quite old and so I would recoment buying by price. Try either:  newegg. com           of        Tiger.com  both of which stand by the products they sell. I also suggest that you not purchase more than two 1gb chips as I believe SDRAM doubles the transfer rate only in pairs. Good luck , Corentint
Posted on Mar 12, 2009
  • 5 Answers
SOURCE: Memory won't add on a Gigabyte GA-6VEML
First of all its showing you only one 512 RAM in one slot. take out the other 512 RAM and before placing it back gently clean the RAM slot and then place it firmly it should show you 1Gb. If it does not happen please try to interchange the RAM and try to know if the 512 RAM is not Faulty.Get it checked by the Shop from where you have purchsed.
Thanks
Ashish
Posted on Oct 28, 2009
xptareq2000
  • 1447 Answers
SOURCE: GA-770TA-UD3 memory configuration error. I
You can use only 2 pcs Ram not 3 pics because you not mantain channel
Posted on Mar 17, 2010
Is a Trident TGUI9680-1 graphics card compatible for a Gigabyte GA-M61PME-S2 motherboard?
These cards were new back in 1995. It WILL work installed in one of the PCI slots, but you will probably have to settle for the default VGA drivers since there most likely won't be anything available for the newer OS's. Don't expect great video quality of fast performance either since machines of that vintage clocked around 200 Mhz, unlike the 2+ GHz machines of today. Good Luck!
Jul 15, 2015 | Gigabyte Computers & Internet
Memory support
  1. 2 DIMM memory slots (supports up to 2GB memory)
  2. Supports 1.8V DDR DIMM
  3. Supports DDR2 533/400 DIMM
Note2: Use of a Double-Sided memory module (the single chip is 512 Mbit) is required if you wish to install a 1 GB memory module
Only supports one gig per slot...
Mar 21, 2012 | Gigabyte GA-8VM800PMD-775 Motherboard
The ram slots on my ga-81865gm-775-rh-as MB are reporting my ram chips as 512k each rather than 1g each. The chips are 400mhz, supported, Kingston kvr400x643ak2/1g. I've already removed the ram and...
Hi, you can download a manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=2358#manual
Your mainboard supports:
Type: Dual Channel DDR 400 / 333 / 266 support
  1. Max capacity: 2 GB
  2. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
Its maybe a setting in the bios or you missing a driver that causes the problem.
Or one of you ram modules is defect.
Sep 04, 2011 | Gigabyte GA-8I865GME-775-RH LGA 775/ 865G/...
WHAT GB RAM SOPORT IN DIVES
The Gigabyte mainboard you have uses DDR333, PC2700 RAM memory.
Your model GA-81845GVM-RZ has 2-slots and each slot can have up to a 1GB of memory, therefore you can have 2GB total RAM memory on this model mainboard.
I recommend mainstream, reliable pair of 1gb each memory modules such as Crucial.
Good Luck
Aug 31, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
Motherboard will not run with 8gig mem
I suspect this is a memory compatibilty problem - the memory you have listed is not on the GA recommended memory list see - http://www.gigabyte.com.tw/FileList/MemorySupport/motherboard_memory_ga-ep45-ds5.pdf
Note The memory spec of what you are using is set at 2.1v yet your motherboard spec is 1.8v also the latency of your memory is spec 5-5-5-15 2t at 2.1v and 1066mhz - the motherbaord and recommended memory is 5-5-5-15 / 4-4-4-12 at 1.8v at 800mhz
Try down specing the system memory to run at 800mhz not 1066 - this will reduce your processor speed as well, but at least it might work. there is no guarantee as the latency at 800mhz is 5-5-5-18 for your memory.
Simon
Jul 07, 2009 | Gigabyte Motherboard Socket775 -...
Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
This is the website link for your board on gigabyte website. http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2159&ProductName=GA-8VM800PMD-775 Suggest you have a faulty piece of ram or a clock speed miss-match. your board supports up to 2gb of memory.Try also reseating the memory. Let me know how you get on? chris http://www.motherboardsrus.net
Jun 06, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
