Question about Mintek DTV-263 26 in. LCD Television
I can't get full screen view. The manual says use the WIDE button on the control, but my controller has no such button.
  • 362 Answers
Try to change the aspect ratio from the video menu. With the remote or from tv control panel pull up the menu and make the change there.  Let me know if this helps and please rate this solution.  lone99star
Posted on Jan 11, 2009
How do I make the screen on my sanyo tv full- It has a black bar top and bottom
Your TV remote control (not the cable box remote control) would have to have a button that would allow the changing of the TV screen sizes. My Sony TV control has a button called, ' wide', and when pressed will change my screen to either, full, wide zoom, and zoom. Only zoom gets rid of the black bars on my TV. If no button, than the screen size will be determined by the broadcaster.
Feb 10, 2013 | Sanyo DP26640 LCD TV
HOw do I Reverse Full Screen?
Refer the user manual to your TV and check how can you change the aspect ratio of picture. Changing aspect ratio will change the height of the picture.
May 10, 2012 | Universal Remote Control Osiris Complete...
I have an 32 inch LCD tv which is about 2 yrs old. Was watching tv when the screen went from normal viewing to zoom1. Followed directions from manual, which said to select imput on the remote then select...
Try this. On your remote control there should be a button that says "Aspect" hit that button and it will probably say "zoom1" or "zoom". If you continue pressing the button it will give you several option. My TV is set to "Wide" which is what I am sure yours should be as well. Or simply continue pressing the button until the picture is at the setting you are accustom too.
I hope this helps with the problem,Jason
Jan 02, 2012 | Televison & Video
The screen is wider than the screen on my tv. tv screen to view is expanded like for a wide screen tv
There should be a format button on your remote control. If your using a satellite receiver or a cable box the format button might be on that remote.
Mar 01, 2010 | Televison & Video
Can,t get full screen view on TV. Manual says use the WIDE button, but I don't have such on my controller.
The buttom might be labled aspect or wide mode or view mode. If you cant find it you can change the aspect ratio of cable and sat boxs to match the tv
Jan 10, 2009 | Televison & Video
Can't get full screen view
look for an aspect button, otherwise, go into the menue, find video,or pickture, and look for screen format, or pic size, or aspect
Jan 10, 2009 | Mintek DTV-263 26 in. LCD Television
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Full screen
The black lines are because you are playing the analog 4:3 picture on a newer 16:9 shaped screen. If you don't have the manual, you can get it by going to www.sharpusa.com and search for your tv model listed. The user guide is available in pdf format.
According to page 35, you need the "view mode" button on your remote. You sound like you want it set to "S" for "Stretch".
enjoy your TV,
Herb
Sep 05, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mintek DTV-263 26 in. LCD Television Logo
57 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
