Question about Samsung HLR5067WX 50" Rear Projection HDTV
What does it mean when there is no picture and the standby temp light on continuously
If I click the tv off and them back on w/remote it does show picture then after a few minutes goes black and standby/temp light goes on...the light does not blink.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
It means the set is in shutdown and it based on model listed here has a power supply or related problem.
Posted on Dec 22, 2012
SOURCE: Samsung DLP won't turn on-rapid clicking sound, lamp light blinks
it was bad bulb
Posted on Mar 04, 2009
  • 150 Answers
SOURCE: Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Posted on Jul 07, 2007
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
  • 556 Answers
SOURCE: Samsung HLR5067W replaced color wheel, LAMP light blinks
according to samsung this is indeed the problem.
Posted on Oct 20, 2009
Testimonial: "Excellent expert advice. Confirmed what I believed to be the problem and it was. Very knowledgable"
  • 979 Answers
SOURCE: tv keeps shutting off with standby and lamp light
Good Day sir/maam, if your TV shuts off regularly, means that the power supply section is overloading, this may be due to faulty parts inside your TV, or either the AC mains in the community is to low or to high. If you want you can temporarily use a spare Auto voltage regulator with 500 watts, use it to levelize the AC main, if symptoms still persist, you may need to call for service. hope this helps. thanks
Posted on Oct 23, 2009
Finlux tv showing black screen after switching on by remote. standby light is flashing buy mo picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Oct 08, 2016 | Finlux Televison & Video
The TV keeps going into standby mode , comes back to proper picture and with-in 15-20 seconds goes back into standby mode. It happens continueously.
May I know if the standby led light at the front panel is blinking, if so please count how many times it will flash to determine the error code? If not follow the steps below.
In standby mode press the button of the remote control in sequence, " Display ", " Channel 5 ", " Vol (-) ", " Power ". Self diagnosis screen will displays. Le me know the result.
Jdvillanueva
Sep 02, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
While setting up the Crest Universal remote control RCP1F for my sharp TV, I've managed to turn the TV off, but now I can't turn it back on. The TV remains on Standby and turning off the power doesn't do...
OKAY TRY THIS..
DO STEPS 1-3 AGAIN AND ONCE IT TURNS OFF KEEP CLICKING THE CURSOR UP A COUPLE TIMES.
THEN START CLICKING THE CURSOR DOWN SLOWLY TELL THE TV TURNS BACK ON AND ONCE IT CLICKS BACK ON HIT THE TV BUTTON ON THE TOP OF THE REMOTE ..
IF THE LIGHT BLINKS TWO OR THREE TIMES MORE THEN LIKELY YOU'VE PROGRAMED IT =)
AND NOW KICK BACK RELAX AND ENJOY A COLD BEER FOR THE BOTH OF US =)
Nov 18, 2010 | Televison & Video
Have the 6165wx tv won't turn on flashes 3 lights timer lamp and standby/temp any suggestions?
The tv's lamps life span is about 3,000 hours of viewing pleasure. Some lamps exceeds and some barely reached the 3,000 mark, but when this happened you will not have any pictures showing, but it have sounds. This means that lamp is already burnt out and needs to be replaced.
Sep 08, 2010 | Samsung Televison & Video
Standby light stays on and the tv will not go on
Please check batteries in remote that seems not working. Sony TV would either turns On or standby light will blinks if TV gets any internal problem.
You question shows standby light stays On that means TV does not receive power on command from remote.
If standby light is blinking in sequence, let me know how many times it is blinking and also intimate exact model number of TV to find out possible solution.
Thanks.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My Sony Trinitron TV does not show picture. The standby light comes on and blinks 7 times then pauses and then blinks 7 times. This continues to repeat itself. TV never shows picture or sound. Light...
The usual cause of this is the sensing IC (there are 2 of them) on the power supply board. Sony usually recommends pulling the board and returning it to them for service.
Oct 20, 2008 | Televison & Video
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Sep 27, 2007 | Televison & Video
Samsung HLR5067WX 50" Rear Projection HDTV Logo
135 people viewed this question
Henry  Thomas
Henry Thomas
