Question about Sony PlayStation Portable (PSP) Console
What is ip address
Just put psp on internet, everything seemed good. got to address entry and entered a website, response IP address out of time. what is IP address and what do I need to do to get on internet with psp
  • 53 Answers
To fix go on ip chiken.com it will give you your ip
Posted on Jan 10, 2009
How to change ip address
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at Ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always..It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always .. You can also display your ip from Canada using proxy,even if you are in USA.
Aug 27, 2013 | Computers & Internet
What is the meaning of IP
IP Address stands for internet protocol...its a kind of internet communication protocol.....
The Internet Protocol is responsible for addressing hosts and routing datagrams from a source host to the destination host across one or more IP networks.
it having two types
1>static ip address(which is used by any hosting company)
2>dynamic ip address(which we genrally uses)
and it having two version
1.IP V4
2.IP V6.
i think its enough if you want to know more about it then feel free to contact........thnks blacktulips
Aug 11, 2011 | Computers & Internet
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
How do you assign an ip address to a toshiba estudio 167? I cannot find the option in the menu of the machine.
1)press user functions
2)scroll down to initial setup and press enter
3)scroll down to network and press enter
4)scroll to TCP/IP and enter
5)scroll to address mode and enter
6)scroll to dynamic(automatic address) (or select static ip for manual entry) and enter
7)press cancel ONCE to return to network menu
8)scroll to "complete" and press enter (this will save changes and initialize network)
TO put in a manual IP address at step 6 above select static IP
7)scroll to IP address and enter
8)enter IP address and enter
9)scroll to subnet mask and enter
10)enter value and press enter
11)scroll to gateway and enter
12)enter value and press enter
13)press cancel once
14)scroll to "complete" and enter
exit out of everything
Jan 14, 2010 | Toshiba E-Studio167 Copier
Ip-address
IP address is an Identifier for a computer or device to connect on a network. To know about your IP address, click this site Ip-details.com. To find the IP address of websites like Google, yahoo and AOL.com, select Domain Host search in that site.
Sep 14, 2009 | Computers & Internet
I cant get conneted to the internet on my psp
if you have a router you need to go on network connections on your psp and enter your internet details from the help of your pc. otherwise search for available networks and see if there are some without any security. tapp them and it should work. try it a couple of times around the house and you should be able to get a decent connection. Otherwise you need your own connection. Good luck :D
Aug 05, 2009 | Sony PlayStation Portable (PSP) Console
How do you set the IP address for network use?
Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. eg - IP address = 192.198.0.1 & Subnet mask = 255.255.255.0.
Jun 24, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Psp internet doesn't work.
Try power cycling (turning everything off for about a minute) and connecting again.
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Cannot Use Wireless LAN
the problem is common, you need to set up the psp manually and not let it obtain an ip address automatically. the easiest way is to find either your router ip address or your pc's ip address e.g if your routers ip address is 192.168.2.1, then your pc's allocated address will be 192.168.2.2, so set your psp address to 192.168.2.3. you will also need to set the gateway address, this is your routers ip address(the one you type in your browser to get into the routers settings).e.g 192.168.2.1. the DNS setting will be 255.255.255.0, all other address settings required will be the routers ip address eg 192.168.2.1.
Aug 02, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
