Bush 42in lcd tv s642f will not turn on either by remote or on off switch
Hi I am having problem with my tv bush model s642f while I am switching the tv on the red light keep flashing an it won't come on please help me thanks
It's possible it may be an error code. Depending on the number of blinks it will tell you what to look for when diagnosing the TV.
Feb 13, 2015 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Remote control not working
vizio remotes are junk. I have 70 inch led smart tv and both remotes are junk. I have no idea what brand is better to replace it with.,
Sep 19, 2014 | Vizio M422I-B1 42IN LED LCD Smart TV Full...
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Hi
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sully
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
Factory reset Bush s642f
You have to enter its service mode option to do this. It is a skilled work. Just check this, and see whether you can do this or not.
Dec 30, 2012 | Bush Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I tried turning my flat screen on this morning remote would not cut the tv on thought it was the batteries but put the batteries in another remote and it worked what could be wrong
Check the remote control for its infrared emission. Check this link and select the site 'Electro-help' for details. Detailed description is there, about how to check and repair a remote control. Pull up older posts.
Jul 11, 2012 | Vizio GV42L 42 in. LCD Television
I need a sky remote code for a bush s642f
Hello
Sky remote codes for Bush TV are:
246 263 377 037 064 065 310 300 383 399 391 402 547 292 239 312 609 322 339 515 236 389 035 191 232 245 288 714
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK
Jun 28, 2011 | Televison & Video
Bush LCD 2 will not switch on at all, no light at all.
If the TV has no power at all, not even the led light on, and does not respond to remote or button, then the most common is a faulty power board inside the tv.
Apr 13, 2009 | RCA 32V524T TV
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
Electro Med Services...
