Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi 53 projection TV- won't turn on- Red lamp light is on. Tried to turn the tv on and the lamp light turned amber and we heard the sound of the tv and then it shut off and the red light "lamp" indicator came on again.
  • 441 Answers
Unplug the set for over an hour, if the same thing happenes you will need service. Look at the power light, it should be blikning. If you count the # of blinks between pauses it will tell you the problem
Posted on Jan 10, 2009
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
I heard a popping sound in my tv, then it shut off. I turned it back on with no picture, then the green light went off and the red light came on. Is it the lamp?
yes , the lamp went out , u can get a shipone over the internet or buy the original from mitsubishi , i recomment the mitsubishi
Aug 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Picture turned to red then picture disappeared. voice can still be heard. lamp light not on.
The projection lamp is dead.The tv projection lamp in the tv now,been in the tv like 1 1/2 or 2 years,The lamp life span is over. Require replacing a new projection lamp.
Aug 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
