Question about Toro Garden
My toro zero turn mower won't start. I have replaced the battery and soleniod. I can jump the soleniod and the starter will engage and the engine will turn over but the motor still will not fire.
    New Friend:
  • 30 Answers
Possibly a fuse problem. check under the seat. you should see a fuse block test all fuses with an ohmmeter
Posted on Jan 27, 2013
  • 5 Answers
SOURCE: Toro ride on mower won't start
Try replacing your spark plug. If that fails then go to the engine, cheak your carb, lines, and gas. cheak for gum in the engine/carb. If gummed then get carb cleaner and spray twice, wait 1 hour then try again. If my solution fails then you might need expert help. Good Luck!
Posted on May 24, 2009
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
  • 13 Answers
SOURCE: I have a Toro Zero Turn mower that won't start. I
two things possible you have a sticking float or if its old enogh the electrical ign system is going to have to be replace cheap and easy if the model is old enough this electrical ign takes the place of points and works the same
Posted on Nov 06, 2010
SOURCE: snapper riding lawn mower won't start
my snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
Posted on Nov 26, 2010
Knucklebstr
  • 222 Answers
SOURCE: my toro mower won't start.
The Toros have a Tecumseh engine and are famous for this. I'd suggest you do a thorough cleaning of the carburetor, but there is a little known secret that I've learned about this particular carb. Pull the bolt from the bottom of the float bowl on the carb (1/2 inch wrench; the "main jet"). Be sure that all the little holes in that jet are clean and you can stick a wire thru them. There is a microscopic hole at the very top of the threads on that brass bolt that often gets clogged and your mower will not start. I use the wire from the needle valve inside the carburetor to stick thru it, as it's about the only thing that'll fit. (note: if you have 50 year old eyes like me, you can't even see this hole w/out specs). Hope this helps and best of luck to you. (also, be sure you put the float bowl back on the right way; there's a bevel in the back that needs to go toward the hinge in the float or the float won't work. Learned that one the hard way as well. )
James
Posted on Aug 21, 2011
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
How to remove starter on Toro Z master with kohler 26 HP engine?
First disconnect the battery. Then unhook the wires from the starter should be one or two wires. Remove the bolts from the starter two or three bolts.
Jul 24, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Engine wont start
Make sure wire from battery to starter is connected and there are no problems with wire ( I.e. no missing insulation, cuts and connection to starter is secure.) Also starter may be bad.
Apr 19, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
1642Z won't turn over
jump direct to the starter if it cranks over check the safety swithes
Aug 11, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
I have a Toro Zero Turn mower that won't start. I have replaced the battery and have tried jumping it with a Auto but no favorable results. The engine will turn over untill the starter meets resistance...
Nov 05, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to...
Jul 27, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Garden Logo
1,310 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
