TV Picture is green
Well I have a Mitsubishi HD 1080i series projection television (Mitsubishi WS-55807). Whenever I plug anything into my DTV RGB input (480p/720p/1080i) the color of the picture is very green. This is the only input on the TV that is 1080i compatible. I took the back of the TV off and found that when something was plugged in there the only tube that was working was the green one. The red and blue where not working. Whenever I plug something into my other inputs (yellow,white,red and even my other RGB inputs which are only 480p compatible) I get a normal display. I don't know if that input is fried or what. FYI as of yesterday the input worked fine with my satelite reciever and HD package in 1080i. Could you give me an idea of whats happening and how much it would cost to repair. The tv is old but I love it, but I'm not planning on fixing it if its too much. Thanks for the help!
  • Bonzie478 May 03, 2009
    The 60 inch set went off 1080i and while trying to restore the picture I touched (changed) color settings. When I finally restored the 1080i input setting, I messed up the color. Most of the picture was green. Now we have blue and red but the background is mostly green and annoying and hard on the eyes.
I've corrected the green screen issue by plugging the blue, white, and yellow cable into the component 1 slot.
Posted on Jun 14, 2009
    Problem Solver:
  • 9 Answers
Is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Posted on Jan 11, 2009
Mitsubishi WS-A65 1080 HD Series Won't Switch from 480i to 1080i
Its main digital board has to be replaced. It is a skilled work. If you wish to get more details about this work, check the site linked below and pull up older posts there.
Apr 22, 2013 | Televison & Video
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My television only puts out a pic in 480. The 720 and 1080 are not working. Getting sound no picture
No input on a WS-55511 is capable of 720p . Inputs COMP1 and COMP2 ONLY accept 480i/480p . Input DTV accepts 480i/p and 1080i . When using Input DTV with a component connection(YPbPr) and you get a green or no picture then you will need to navigate the menus and setup input DTV for YPbPr instead of RGB.
Oct 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
HDTV comes up green
there is a setting in the menu under setup i believe it is called "LABEL VIDEO INPUTS". check you owners manual. you need to make sure that the DTV input is set to YPbPr NOT RGB.
Feb 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WS-55857 55 in connection problem
Feb 22, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-65869 tv
You should have everything you need. I really don't think you have to order anything. Make sure you have whatever set top box you are hooking up to TV on the correct mode or setting... 1080i 720P 480P 480i etc....If you have any other questions... email me back or hopefully this was enough to get you up and running. Good luck and Happy Holidays....Jay
Dec 28, 2007 | Mitsubishi WS-65311 65" Rear Projection...
How do i get my tv at 1080i
First of all your system, tv, must be able to perform your request, Secondly, your service must be able to provide the 1080i or 1080p, not all service's provide the service with the equipment they provided you (your box). Check with your provider.
Nov 17, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Can't display 1080i from DTV
you may have to go to setup and turn on this setting
Aug 28, 2007 | Mitsubishi WS-55807 TV
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
