Anonymous Posted on Nov 29, 2012
Question about MFP digital service kits
Are auto updates able to be turned off?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Nov 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
1236
Points
34
I would just send them to spam.
Fs 1035mfp reset maintenance kit message
hi
find link for solution
https://www.youtube.com/watch?v=Dco3csuDDkQ
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
I've tried to reset the maintenance-kit counter with this procedure but had no success 1 Turn the MFP off and then on. 2 When the memory count appears on the control-panel display, press and hold 6...
You can try to go in the service menu.
You can find this in the administration menu, go all the way down and you will see "service".
You need to insert the service code : 11434506
From there you can reset the maintenance count i guess.
1helpful
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
18helpful
HP 4345. Need to reset the Maintenance kit error. How do I get into ther Service Mode and how do I reset it? Thanks!
2answers
49 2f81- error
From the service manual:
A critical firmware error has occurred. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the MFP. Other causes include poor quality parallel cables, poor connections, or specific software programs.
To fix:
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs, disconnect all of the cables that
connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
To upgrade firmware:
The MFP has remote firmware update (RFU) capability. Use the information in this section to upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software. This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
This procedure requires that you install HP Web Jetadmin Version 7.0 or later on the computer. See Using HP Web Jetadmin software. Complete the following steps to update a single device through HP Web Jetadmin after downloading the .RFU file from the HP Web site.
1 Start HP Web Jetadmin.
2 Open the Device Management folder in the drop-down list in the Navigation panel. Navigate to the Device Lists folder.
3 Expand the Device Lists folder and select All Devices. Locate the MFP in the list of devices, and then click to select it.
If you need to upgrade the firmware for multiple HP LaserJet 4345mfps, select all of them by pressing the Ctrl key as you click the name of each MFP.
4 Locate the drop-down box for Device Tools in the upper-right corner of the window. Select Update Printer Firmware from the action list.
5 If the name of the .RFU file is not listed in the All Available images box, click Browse in the Upload New Firmware Image dialog box and navigate to the location of the .RFU file that you
downloaded from the Web at the start of this procedure. If the filename is listed, select it.
6 Click Upload to move the .RFU file from your hard drive to the HP Web Jetadmin server. After the upload is complete, the browser window refreshes.
7 Select the .RFU file from the Printer Firmware Update drop-down menu.
8 Click Update Firmware. HP Web Jetadmin sends the selected .RFU file to the MFP. The control panel shows messages that indicate the progress of the upgrade. At the end of the upgrade
process, the control panel shows the Ready message.
HP Web Jetadmin is a Web-based software solution for remotely installing, monitoring, and troubleshooting network-connected peripherals. The intuitive browser interface simplifies crossplatform
management of a wide range of devices, including HP and non-HP printers. Management is proactive, allowing network administrators the ability to resolve printer issues before users are affected. Download this free, enhanced-management software at www.hp.com/go/webjetadmin_software.
To obtain plug-ins to HP Web Jetadmin, click plug-ins, and then click the download link that is next to the name of the plug-in that you want. The HP Web Jetadmin software can automatically notify
you when new plug-ins are available. On the Product Update page, follow the directions to automatically connect to the HP Web site.
If installed on a host server, HP Web Jetadmin is available to any client through a supported Web browser, such as Microsoft Internet Explorer 6.0 for Windows or Netscape Navigator 7.1 for Linux. Browse to the HP Web Jetadmin host.
Replacing the formatter
1 Slide the formatter cover toward the left side of the MFP and remove it.
2 Remove two thumb screws (callout 1).
3 Slide the formatter toward the left side of the MFP, and then remove it.
NOTE Dislodging the formatter might require considerable force.
I hope all this information helps! Thanks and please take a moment to give this solution a rating of fixya.
OKI C3530 MFP
Looks like a fuser problem.
Re-saet the fuser.
Check for pieces of paper, etc. in the path.
Service call 155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Yes
Reinstall the fuser after its
connection connector is cleaned
Turn on the power supply again
If error still exists_
Replace M32 board after check
the cable connection.
2answers
How to install scaner kit
The scanning features is built in with the MFP. What u need to do is connect to the MFP, install the viewer driver, u can start scanning...
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
k24674
ADMIN Andrew
ADMIN Andrew
