Question about Panasonic Toughbook CF-51 Notebook
Locate battery where is the bios battery on a panasonic cf 51 located and how do i take it out?
    President:
  • 2,110 Answers
Actually thr bios battery is on the motherboard ..u have to open the laptop and look for it..
Posted on Jan 10, 2009
How do I reset the bios Password on a Panasonic Cf-51
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Oct 10, 2016 | Panasonic Toughbook CF-51 Notebook
Panasonic toughbook cf-51 drivers audio
The audio or "Sound Drivers" for the Panasonic
Toughbook CF51 are located at:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Please remember to choose your operating system
and click on the "Download Now" button located at the
right hand side.
Gracias and de nada.
Good Luck. Buenas suerte
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Dealer since 1989
Aug 29, 2012 | Panasonic Toughbook CF-51 Notebook
Battery calibration for cf-29 panasonic laptop download
On the Panasonic Toughbook CF29 MK1 Model,
the Battery Recalibration application is actually
built-in on the BIOS. On all other models, it is
a downloadable software located at this website:
and then find the Battery Recalibration Application.
Finally click on the "Download Now" button located
on the right hand side.
Good Luck!
Regards
Panasonic Canada Toughbook Authorized Dealer since 1989
Aug 21, 2012 | Panasonic Toughbook CF-29 Notebook
I need an owners manual for a Panasonic CF-51
ALL Drivers and Owners Manuals for
ALL Panasonic Toughbook Models are
located at the following website:
Make sure to select "Manual" on the menu on the
left hand side, fourth down from the top.
Good Luck!
Regards,
May 30, 2012 | Panasonic Toughbook CF-51 Notebook
How to replace cmos battery in a Panasonic CF-51 laptop. Need to know location in laptop and can not find manual that shows it.
If you need to ask "how", you should STOP and take your computer to a qualified technician, because opening-up a laptop is not an "end-user" repair.
Jan 22, 2010 | Panasonic Toughbook CF-51 Notebook
I cannot remember my Bios start up Password on my Panasonic Lap Top CF-R6
you can reset passw, but reset bios to defaults, need to enter time and date.
Note: disconect power, and release battery module.
you need to open laptop case, for these:
1st : check for screws below laptop, with keyboard label, take them out. check for plastic cover on keyboard (top), and take this out, (very carfully is very fragile).
then take the keyboard out (check for small fragile plastic cables).
look inside for any battery (module or big/small clock battery inside).
try to reach , and take this out ( connector or battery) , if dont see-it you may need to open all laptop bottom case. take all bottom screws and open carfuly the case, ( 1st take the memory, hd, cd drive, and so on. Out) and check where is the battery is located. and take very carfully on removing boards and so, is very fragile boards.
then remove battery out, wait a 1min and then reaseable all again, in the same order and same screws positions. and your problem is repaired. when power up. you need to enter bios to configure date and time. and reboot to test.
Jan 02, 2010 | Panasonic Toughbook CF-51 Notebook
Keyboard is stuck in numeric mode. Can't type
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Oct 02, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Andrew
Apr 09, 2008 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 Notebook Logo
206 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
