Question about Coleman Propane Grill Stove 9921-700
Black is on the burners
I have a problem of black soot from the burners on my 4 bunner hotpoint propaine apt stove.
  • 494 Answers
It's also possible that your stove is not converted to the right type of gas. If you are using propane, have you had the stove converted from natural gas to propane? If you are living in an apt with natural gas, then your propane stove will need to be converted to natural gas.
Posted on May 15, 2010
  • 700 Answers
The fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Posted on Jan 11, 2009
How to fix la germania burner?
Guess you mean a kitchen appliance not a cd/dvd burner! The only way to help you giving some advice about how to fix ut is if you tell us the problem you need to fix.
Describe your burner: is it a gas burner or an electric burner?
Had you repaired something similar before?
In any case, watch some youtube tutoriasl to repair a burner
Cooktop Range burner not heating burner light is on GE Hotpoint RCA...
GE Hotpoint RCA Gas Stove Repair Burner is not working JGSP44BEY3BB
Prego Project Fix GE Stove Burner
Stove Oven Range Burner Repair Diagnostic GE Hotpoint Kenmore Sears RCA...
Aug 19, 2015 | Computers & Internet
Why is there black soot on gas stove burner? What can be done to resolve this issue? Can it be cleaned or does it need to be replaced with new burner valve?
I recommend you have gas company or appliance service. Gas is nothing to "fool" with. It sounds like a fuel (gas) air mixture problem. Have you "cleaned" underneath the burner recently and by chance not re-installed the burner properly? Or someone else? Double check. If you see something obviously wrong, correct it. Otherwise as above.
Mar 06, 2015 | Kitchen Ranges
Since it has turned cold my flame on cook stove has yellow flame
It may or may not be related to outdoor temperature but it appears that your burners don't have enough air. See if there is an air adjustor under the burner in the gas piping.
Oct 05, 2014 | Suburban Drop In Black CookTop Stove - 3...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Sep 11, 2009 | Coleman Grilling
Zanussi gas stove
three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Aug 31, 2007 | Kitchen Ranges
Coleman Propane Grill Stove 9921-700 Logo
479 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
