Question about DBX -215 Home Equalizer
I am getting voltage coming out the input think is the voltage ic gone bad
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 232 Answers
Time for shop...
Posted on Sep 20, 2014
What is the ic regulator of philips model: 14PT332/00
regulat IC voltage is electronic component VERY IMPORTANT that has a input example 2OVDC and regulate the outpud to 5VDC or -5vdc, ETC.
IN any circuit electronic regulate supplies for to avoid glitching, rizos, spike. etc
God bless you
Jul 18, 2012 | Televison & Video
How do i get parts for behringer b215d my power ic is burn out
Regards, urgent help.
I have a powered speaker Class D, and the PWM isdead. change the IC 3525, is controled by a NE555 which is shutting down. works when connected to a higher voltage 150v, but turned it off, I think by overheating. I already changed mosfets, and ICs. I think that may be some component failure is triggering the protection, someone could help me. I'm a musician and I depend on this car for my livelihood. Thanks
Jan 06, 2012 | Behringer B215D Powered Speaker (550 Watts...
TV has no sound
Hello
You haven's specified nothing about the picture. Picture is Ok and there is no sound I thinks and posts this solution
Either your TVs speaker or its sound out put ic has damaged. To check it and conifrm you just do this first. There is a stero headphone socket on the front panel of your TV. Insert a headphone pin inot it and listen whether there is sound output come ffrom it or not. If there is sound output from the headphone socket, and not from the speaker, be sure taht the speaker is out.
If there is no sound output from the headphone socet, wither your TVs sound output ic is damaged or it doesn't get proper voltage to go on. It is very easy to locate this IC, as speaker wire goes directly to this section. Just follow the speaker wire and locate the IC, usually screwed on to a metal heatsink. Check its input voltage. If there is no voltage to that IC, check the track associated with that pin. If there is voltages and still not works. first resolder all the pins of that IC by applying a little more solder, whout shorting the adjecent terminals. If this does not helps, replace that IC with same type and number. OK.
Jan 05, 2011 | RCA F27442 27" TV
My I'Art AV-32DF74 by JVC was working fine and then one day the picture and sound suddenly went off although the blue power light stayed on. There was no warning. One minute it was on and the next, it was...
first of all have u check for a bad capacitor on power supply , this capacitor is a 1000uf at 25 volts or 35 volts this capacitor controls the voltage to the secondary voltage , replace this capacitor before u do anything , sometimes it look good but is bad inside , also the other commun problem on this tv is the vertical ic if this ic if bad the tv would go in to shut donw the part # start with la45 or la78 , la76 , also u need to check for a open resistor next to the flyback this resistor work together with the vertical ic when the vertical ic gose bad it open this resistor the value 1 ohn , so 3 things u need to do first replace the capacitor if this dont work check the resistor that is close to the flybak if is open u need to replace vertical ic on this vertical u need to have 28 volts on pin 7 , this is the most commun problem on this tv , i have fix a lot of this tv with this problem before and this is what i have found ,
Jan 04, 2011 | JVC AV-32DF74 32" TV
I have an rca ctc186/7 series tv and it has no sound. We tried cleaning it, hooking other speakers to it and hooking up a dvd player and still no sound.
Hello
The audio output Ic inside your tv has damaged, or it doesn't get proper voltage. You just open your TV, and locate the audio output Ic. It can be located by following the speaker wires. Usually it will be screwed onto a heatsink. Check the input voltage with the help of a multi meter, af it is there, the Ic is damaged. Replacing it will solve the problem. If there is no voltage, follow the supply track and find out the opened circuit point. Usually a small value resistor, say 0.01Ohms in value, will be connected in series with the power supply to Ic. If it gets opened, there will be no supply to Ic, resulting no sound. If the audio outpu Ic get short this resistor will open. So keep in mind that, if this resistor is opened, there may be a short inside the output Ic, or come capacitors fitted with this supply line, after the reistor. Check the also for any short. keep a keen look at the solderings fo the leges of this output Ic. Some loose, or bad solderings also may be there. Anyway, your TVs audio output section is faulty. Find the reason and rectify it. If audio Ic is found defective, desolder it out from the board, and replace it with a same type and number. Ok
Gopakumar. India.
Nov 21, 2010 | RCA Televison & Video
Tv comes own and popes about ten times. and it also goes off. blue light comes own and blinks constantly. what could the problem be?
there some problem with your power supply.there is some drive ic,fet or ic link problem. check voltages if there some of missing which is menstion on board .then use to check same line you must find out problem.
Oct 18, 2010 | JVC AV-56WP74 56" Rear Projection...
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Problem with SmartUPS SU5000I
Before trying to replace an IC, make sure that the battery is capable of holding a charge. If there is more than 1 battery, check all. If it (they) are bad, it will probably be less expensive to replace the unit.
Jul 24, 2009 | APC (SUA3000I) UPS System
No output
If the board is not cracked , check voltages at the audio output relays. on the input audio terminals side of the relays ,if you have voltage you may Have bad output Ic's
Jun 29, 2007 | Yamaha RX-V690 Receiver
No power, LED blinking, Low voltage regulator IC?
check for bad solder connections then check all fuses the ones that look like resistors too get back to me
May 22, 2007 | Toshiba 57HX81 57" Rear Projection...
DBX -215 Home Equalizer Logo
41 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Themcramers
Level 1 Expert
Tom Chichester
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
