Question about Juki Sewing Machines
Juki Bar Tack Machine Cutter not working
Bar tack machine - cutter not working following a jam
  • Juki Master
  • 1,564 Answers
I can't help. But I would recommend calling your local Juki Dealer for the name of a good repairman. Juki's are expensive you don't want to be futzing about if you aren't an expert.
Posted on Nov 30, 2012
akylas
  • 26 Answers
SOURCE: Juki MB-373 Button Attaching Machine
Use a thicker needle.
Release the looper screw and move it back and close to the needle, but without touching.
Tight the looper screw.
Adjust the needle through (left and right) wider.
Posted on Jun 09, 2008
SOURCE: Bobbin Thread cutter no longer works
I have a designer SE, I ran across this site and found it very helpful. This person is a retired machine repair person and has a wealth of knowlege. <http://www.sewmuch4retirement.com/tips.html> from what I understand the blade needs to be cleaned as part of the Maintenance, it also can be replaced.
Take a look at this site, perhaps it will help
Far Away Grandma
Posted on Oct 26, 2008
  • 23 Answers
SOURCE: I have a designer 1 sewing machine and the cutter won't go in
if you are referring to the arm on the left side of the bobbin, just push it back in. You may need to use the end of the small screwdriver.
Posted on Aug 13, 2009
  • 2976 Answers
SOURCE: necchi 3101fa thread cutter on the machine
It is at the needle screw area. Item #20 on the picture.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Sewing_Machine_Manual_Pics/Necchi_Pics/Necchi_3101i.jpg
Posted on Oct 05, 2009
Testimonial: "Awesome dude thx was lookin for like 30 min to find a damn diagram of the machine.... lol thx again. -THCjake"
name_mac
  • 28 Answers
SOURCE: my juki tl98q foot pedal and thread cutter has
Check the power cord and then take apart the side door and check the thread cutter for any displaced working machanisms. OK!!
Posted on Mar 26, 2010
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
Manual backtack lever works but electronic servo backtack only engages when machine is at rest with needle in up position.
hello there
at normal case needle bar must be in upper position because DDL-8700/7 does not equipped with needle feed. for your problem please check back tack solenoid open and close when you make back tack ( sometimes it was jammed and need to move by hand ).
best regards
ashraf abozid
Cairo - Egypt
aabozid@hotmail.com
Aug 18, 2015 | Juki DDL-8700
Juki straight stitch upper needle broken off and stuck.
You could try to pull it down with a magnet or see iff it will stick to some blu tack and pull it out with that.
Nov 02, 2012 | Juki DDL-8300
Thread cutter not working
you might consider having the machine serviced to find out why the thread cutter isn't working
Apr 30, 2012 | Juki TL-98Q
We are hving problems with the juki ddl 550. the automatic thread cutter is not cutting.
hi there
1 - remove throat plat and mak sure the movment for thread cutter working or NO if working maybe need to change fixed knife or movable knife.
2 - if no movment mak sure plug for cutter solenoid is connect secur.
3 - make sure the output signal is coming to the cutter solenoid or no.
4 - maybe solenoid is dameged and need to change.
with my best regards
ashraf abozid
aabozid@hotmail.com
Nov 05, 2010 | Juki DDL-8700
My juki tl98q foot pedal and thread cutter has stopped working. help
Nov 28, 2009 | Juki TL-98Q
Sewing Machines Logo
94 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
