Question about Canon PIXMA MP160 All-In-One InkJet Printer
What is usb port on front of mp160 cannon printer for?
Front usb port use?
SOURCE: cannon MP160 printer error message E5 and alarm light remains on
Problem with catrige.Printer not detecting the catrige so clean catrige,and insert.
Posted on Oct 20, 2008
yooperbud
  • 8637 Answers
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: cannon mp160 scanner does not work- do not have original CD
use this link here I had the same problem the printer and copier was working fine then I had to click the software and add the software for mp navigator to scan... u can also get drivers for the printer on the same page for anyone who has lost the orginal cd it came with... now it works fine
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Posted on Jun 16, 2009
tepan
  • 28 Answers
SOURCE: cannon mp160 erro code E27. what to do
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-19
Posted on Sep 04, 2009
pineworks
  • 4041 Answers
SOURCE: Cannon Pixma MP160. on/off light keep blinking and won't print
This some times works.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Where can I get a replacement for my 2 front usb ports on my optiplex 760..they are not working??
I've never seen 2 front USB ports that were bad. I've seen 1 that was defective because the USB device that was plugged into it was broken off. However in that case it caused the power supply to short out and prevent the computer from powering on. Here is a link to your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-760_Service%20Manual_en-us.pdf
If the USB ports on the back of your computer work then the front ones should too unless there is a connector dislodged to motherboard. All USB ports use the same circuit.
Jan 29, 2013 | Dell OptiPlex 760 MT Desktop Computer
Gateway 5632E usb high speed ports locations
You can view the rear I/O panel of the GM5632E (including six USB 2.0 ports) atGateway Support - Ports.
The front view, including two USB 2.0 ports is atGateway Support - Front View.
May 02, 2012 | Gateway Computers & Internet
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
The Cannon MP160 shows E22. I don't know whats wrong with it
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Feb 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
HOW TO CONNECT FRONT SIDE USB PORTS
*********** board as option to connect the front usb ports check where the ports are available, insert the cable your front usb port will be work.
Apr 05, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
A few days ago, my computer started giving me the message "USB Device Not Recognized", and I soon realized it referred to my PIXMA MP160 printer/scanner. I've tried almost everything including reloading...
Try disconnecting unit from USB port, restart computer, and reinstall unit. Might try another USB port on computer. It also may be a bad printer/scanner! Try it on another computer.
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Usb not working
Check that all the USB ports are turned on in the BIOS setup.
Apr 02, 2009 | PC Chips (M925G) Motherboard
My Cannon MP160 computer scans ok, but when i try to print it says error:  printer is offline
Jan 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
81 people viewed this question
old marine
old marine
