Question about Dryers
Taking longer than usual to dry. Vent is clear
Taking longer than it used to to dry. Approximately twice as long as it used to in the past. My husband took the vent/hose apart and there are no kinks or obstructions.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You need to check the internal duct work for lint buildup.
Posted on Nov 30, 2012
3 Suggested Answers
  • 4 Answers
SOURCE: dryer taking longer and longer to dry
The only way to clean the dryer out would be with a vacuum cleaner and a flexible hose. Cleaning it may help but your problem more than likely isn't lint build up. The gaskets on these dryers wear out pretty quick and don't seal as well as they should. Usually cleaning will help for a little while but it will not solve the problem.
Posted on Dec 15, 2008
rickead1
  • 1998 Answers
SOURCE: Problem: Dryer taking longer than
Moisture build up in a dryer mainly happens due to blockages of lint in the unit. Lint prevents the heated air from circulating through its proper paths and when you add wet clothes to the unit sometimes the lint that is trapped in your unit can hold that moisture makeing the dryer work harder to try and dry the clothes click on this link to view a tip I wrote on how to alleviate this problem http://www.fixya.com/support/r8732702-prolong_life_dryer if you have any further questions please message me back and also remember to remove that rear shroud that covers the blower fan wheel this is where i find when people use those dryer lint removal tools it doesnt actually help that much in fact it ends up pushing the lint down and packing it into a tight corner makeing it harder for the dryer to dry the clothes I await if you have any further questions Thanks again Rick
Posted on Jun 12, 2011
Started taking longer to dry clothes
Richard,
Start with checking your vent line. Usually the first cause of extended drying time is some type of restriction in the exhaust line. If you have a long line that goes under the house, a good way to clear it out is to use an electric leaf blower and stick it in the exhaust line and turn it on slow and then gradually turn the speed up. You will need to take of the vent cover on the outside of the house before you start blowing anything out. Hope this helps!
Jun 22, 2015 | Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
My dryer is working and heating but it's taking more time than usual to drye the clothe
hello vic.... when it takes longer to dry the clothes check the vent pipe and the outdoor vent for lint buildup! Joe
Mar 14, 2011 | Dryers
My dryer is taking to long to dry clothes and the setting dial moves very slowly if at all.
Make sure the exhaust vent is free and clear. Lint build-up can cause it to take longer to dry clothes. Also, try putting the timer on another setting to see if it makes a difference. If you are using "Auto", try putting the setting on a manual time setting to see if that helps. You may have a bad timer or bad moisture sensors.
Feb 24, 2010 | Maytag Performa PAV2200
Not drying like it used to
The Load will make a differance on how long it takes to dry. I would check your exhast vent for the dryer and make sure its clear. the vent hose from the dryer to the wall should be clear and not crushed. if it is, a 50% crush or blockage will make it take 50% longer to dry. the vent from the wall to out side the home could have a blockage or some of them have those little vents that open when the dryer is on. and sometimes they get stuck, this will cause a longer dry time.
Turn on your dryer and Find that ouside exhaust vent and if you can reach it, make sure its blowing strong. and with heat and nothing blocking it. (( somtimes birs will make a nest in them.))
Jan 08, 2010 | Dryers
The dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Sep 08, 2009 | Dryers
Dryer taking longer and longer to dry
Dec 15, 2008 | Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Dryer takes longer
check the humidity sensor not working
Mar 09, 2008 | Dryers
Kenmore 80 series dryer...takes twice as long as it should to dry
no about all the time this kind of problem is caused by some kind of vent restriction start by looking over th back of the drier with a flash light and see if the vent is mashed folded over on its self or too long you only need enough to hook to the connector to the floor then go to the out side with the drier running and check to see if the drier hood attached to the house is opening i some have a plastic screen attached to the hood to keep critters out make sure that's clear rule is must have a 4" opening from drier to out side hood cant hang down under house and come back up as dryer will fill it with water over a peorid of time now easy way to verify vent restiction is to disconect vent run 1 load and see if it dries in proper time about 60 min
Dec 31, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
