Question about McCulloch Garden
Studs that tighten the bar one is striped how to change them
32cc ms1432 -modelcs38em -sn.050201 -disp.38
    Top Expert:
  • McCulloch Master
  • 2,931 Answers
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
studs that tighten the bar one is striped how to c - helpful-rx44h4hsqebyqg3voy0wii3n-2-0_5.png
Posted on Mar 10, 2018
  • 1388 Answers
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
SRF518
  • 232 Answers
SOURCE: My McCulloch MS1838AV 38cc chainsaw has a broken
only way is to "mike" out the bearing areas and connecting rod journal. compare the original to the replacement. close is not good enough exact is what you want.
Posted on Oct 24, 2009
  • 2239 Answers
SOURCE: how do i replace stud bolts that tighten the bar
if this is the plastic crankcase machine, the bar bolts are pressed into the case, start by removing the muffler, use a punch and drive the broken stud back through the case, it will have a square head on the rear, re fit the new stud, use a spscer and the bar nut to pull the new bolt fully back through.
Posted on Feb 11, 2011
  • 9 Answers
SOURCE: how do i replace stud bolts that tighten bar
if you mean the bar locating bolts they are cast in to the body ,and cannot be replaced
Posted on Feb 12, 2011
  • 342 Answers
SOURCE: Bar studs threads are stripped out on ms1432, 32cc
Wade there is a place called central Spares on the net. They do most parts and they may have a universal one.
Posted on Oct 20, 2013
How do i change the chain on my model 108526-01
The proper sequence to installing the chain should be to first ensure the brake is in the 'unlocked' position then loosen the chain adjustment screw, slip the chain over the back of the sprocket, align the chain with the bar, slip the bar onto the bar mounting studs ensuring the adjustment pin slips into the appropriate hole in the bar. Then slip the outer chain cover over the bar studs, elevate the front end of the bar and tighten the bar mounting nuts to 'snug'. Adjust the chain tension to the desired setting ensuring the front of the guide bar remains elevated, then tighten the nuts to secure the bar.
Remember to unlock the brake BEFORE removing the bar and chain because it is so much easier to unlock it mounted on the saw if yours is the design that comes off with the cover.
Keeping the front of the bar elevated during assembly and adjustment of the chain will keep the chain tension correct for a much longer period.
Mar 01, 2015 | Garden
1995 old cutlass rocker arms wont tighten?
need to know what size motor you have but the 3.1, 3.4, and 3.8 liter motors are know for the rocker arm studs striping out inside of the head so while you think your tightening it your really only turning the nut and the stud. try putting a wrench(13mm) on it and turn to see if stud is turning. if so it will need to be drilled out and a helie coil put in it
May 21, 2014 | 1992 Oldsmobile Cutlass Supreme
Bar studs threads are stripped out on ms1432, 32cc McCulloch. Can they be replaced? If so, how do you do it and where do you get them?
Oct 20, 2013 | Garden
How do i replace stud bolts that tighten the bar
Feb 11, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
Right hand handle bar has slight movement
Are the forks bent in any way? slight dents will cause bars to not tighten as will over tightening the allens on the bars. Remove the allen clamps that go around the fork and check for damage. If you need to remove be careful as to how you remove throddle cable and grip. Allens or screws and label. Then you can raise the bar over the end of fork. My bet would be a striped tread or dent and not the drop bar.
Mar 29, 2010 | 2006 kawasaki ZX-6R
What tool would i need to remove cylinder head bolts on a 93 ford escort gt
Hi
A cylinder head removal tool is provided for removing the cylinder head from the engine block of an engine.The tool comprises an elongated bar made of tool steel with means for bolting the bar to the cylinder head and for mounting pusher bolts which can be tightened down onto exposed threaded ends of frozen studs holding the cylinder head. As the bolts are tightened down onto the studs the cylinder head is gradually lifted upward free from the studs.
Thanks for contacting fixya.com
Nov 05, 2009 | 1993 Ford Escort 4 Door
My McCulloch MS1838AV 38cc chainsaw has a broken crankshaft. I found a crankshaft for the similar model MS1432 32cc.Are the crankshafts the same?
Oct 24, 2009 | McCulloch Garden
Bar stud removal
only had one 20 years ago they were right hand nut side an left hand into block//used the two lock nuts tightened together to pull studs//like over tightening the lock nuts clockwise breaks stud threads loose ..install new same
Mar 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Stripped bar stud
Dec 20, 2008 | Garden
Garden Logo
35 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
