Question about Maytag Skybox Beverage Vendor
Skybox by Maytag Not Cooling
Hello all. I have a very nice Skybox by Maytag. It looks and runs great. All the lights work, the dispensing mechanisms all work flawlessly, the fans run great.....only on problem. It doesn't get cold. The compressor appears to kick on and gets hot to the touch, but it never cools the inside of the unit. I have been doing a lot of research on here and I see a lot of relay stuff. Could the relay/overload be the problem even if the compressor is still kicking on? The reason I think it may be is because occasionally when the compressor goes to kick on, I hear a loud click from the area of the compressor, and nothing happens. If I unplug it and plug it back in, most of the time the compressor will start....but when it does, it still doesn't cool. Relay replacement or trash it?
5 Suggested Answers
  • 298 Answers
SOURCE: frigerator runs constanly till compresser gets to hot
Sounds like it might be the thermostat
sensor bulb is defective see if you can
turn the refrigerator off with the thermostat
the defrost heater is supposed to heat up
enough to open the defrost thermostat
Make sure the defrost timer works to
turn on lhe heater & turn off the defrost tstat
turn the power off and check the tstat & defrost
heater for continuity check to see if tstat open
and closes when you turn the knob,
if you remove the tstat you can check the
bulb in ice water and warm water aborv 40
to see if tstat cycles on and off
Posted on Nov 26, 2007
aasc
  • 1606 Answers
SOURCE: Maytag refrigerator compressor dosen't operate
Did you wire the 3 wires on the overload / relay correctly ?
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Maytag side
You can try the capacitor and relay first, but you may have a fried compressor...the click is the compressor trying to start...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 11, 2010
peyton32034
  • 410 Answers
SOURCE: maytag refrigerator Model mff2557heb wont cool
The compressor in your refig is bad. whats happening is when you let the compressor cool down it will run for a while then it starts binding internally until it gets to the point of humming and clicking. only repair is replacing the compressor. sorry for the bad news...
Posted on Oct 03, 2012
Why did my unit stop cooling beverages?
my skybox run but my beverages is not getting cold,can you tell me what i need to do,or where i can i take it to get fix?
Nov 15, 2012 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox stopped cooling Skybox stopped cooling. Sounds like the relay will kick on briefly and then click off. Everything else works. I took the back panel off and could hear the relay clicking on...
The relay on your box is damaged.. You have to get it replaced.. Not to be tried by a novice but if you have some experience in electronics it can be fixed by you. The relay costs around 75$. Good luck!
Mar 26, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox-2 problems
maybe bad fans and a dispenser motor post your email and iwill send you the svc manul so we can look into it deeper
Mar 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox not cooling
Sounds like the refrigerant gas has leaked out. Any reputable refrigeration engineer can fix this.
Sep 30, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser/Refrigerator
TroJo, Try PartSelect.com for Skybox parts. I ordered a part on Monday night and installed it on Wednesday night. The parts are not that hard to find. Appliance repair services can replace your compressor or add freon. Be sure you have plenty of ventilation behind your machine. Jonmon
Mar 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Vendor Logo
96 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
