Question about Epson PictureMate 500 InkJet Photo Printer
Saturated waste ink pad on epson picturemate 500,how to access pad.
Screen saying ink pad inside this printer is saturated replace ink cartridge before you can run print head clean. how can i access ink pad to clean myself.
Basti
  • 1447 Answers
SOURCE: Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
Posted on Apr 19, 2008
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
glenncuneo
  • 7 Answers
SOURCE: My picturemate 500 is stating it needs a new ink pad
there are actually three ink pads in this model, only one has a sensor and is monitored by an electronic counter. there is a long one located under the the print head as it is printing, and a small rectangular one located on the far right side of the printer and this is the one that gets used during cleaning, and it also helps to park the printhead when you turn the power off The biggest on is located on the very bottom of the plastic base of the printer. The pad you are speaking about is the rectangular one. The only way to reach this pad is to remove the upper assembly of the printer--which means you remove alot of screws the main circuit board, the plastic covers on the ends---5 quick connctors on the back of the mainboard and a total of 8 ribbon connectors--ALL CAN BE DONE WITH NO PSECIAL TOOLS REQUIRED!
A sensor WITHIN the main ink waste pad indicates when the pad is getting soaked. There is also an electronic "counter" which can be reset off of the mainboard, if you have the right software. The photomate 500 has a design limit of roughly 5200 pictures before this sponge gets all soaked up with ink. I have just been using qtips to soak up the ink. I cannot find parts **** as print heads, or inkpads to order online.
If you like, make a post here and I will share pictures I have taken (plus some pages from the service manual......
Posted on Nov 07, 2009
cns assoc
  • 677 Answers
SOURCE: epson Picturemate ink absorber pad is
I found this on fixya per dgsturt
It looks like you've managed to get ink all over the shop by using the self clean option. That't mainly to clear bocked print heads and tends to squirt a load of ink through.
That ink has to go somewhere, it looks like you may have some on your rollers.
First, I'd have a look through the printer menu see if there's a roller cleaning option, give that a go.
Second, I'm not sure but worth a try, try printing a document that has wording all down the page but use an empty cartridge. If your printer will do this you’re effectively using a sheet of paper as a mop to clean the rollers.
Third, probably the most difficult, get some Isoproprial Alcohol from the chemist and try and clean the rollers and print bed yourself with a lint free cloth and cotton buds, what ever works.
If you don't like the idea of Isoproprial Alcohol, it is highly infamable, try with a damp cloth first, but it will take longer to dry off.
OR YOU CAN TRY THIS:
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Posted on Mar 23, 2010
pineworks
  • 4041 Answers
SOURCE: Replace waste ink pad in epson printer (R390) as
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
End of service life error message epson inkjet printer RX700
This refers to the internal counter, actually located in the software on the computer determing that your waste ink pads are likely saturated and need replacement. You can download software from either Epson at http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp or at http://www.ssclg.com/download/sscserve.exe. Both of these software packages will allow resetting the counter. However one should either take the printer in to an authorized Epson or independent printer service company or if comfortable with messing around inside computers and peripherals, one can check the waste ink pad(s). On the RX700 there is a small access panel, on the back of the unit, on the left hand side when facing the back of the RX700. It is held in place with a Phillips head screw and small plastic latch tab on its bottom side. The pad material is clearly visible from here, with a pair of clear plastic waste ink tubes directed down into this waste ink receptacle. If this is saturated, wet and discolored, it should be replaced, before resetting the counter. Not doing so risks the excess waste ink overflowing and making a mess and possibly even shorting out some of the circuitry.
Sep 18, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
EPSON R545 waste ink saturated
You need to reset your printer. Goolgle search for "indoreset for rx595" and download it. That is the program you need to use to reset the waste ink pad counter back to zero.
Jul 20, 2010 | Epson Office Equipment & Supplies
Replace waste ink pad in epson printer (R390) as printer says its saturated
Main features.
Download Free
Apr 10, 2010 | Epson Stylus Photo R390 InkJet Printer
Oct 06, 2009 | Epson PictureMate 500 InkJet Photo Printer
Flashing red/green lights
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. If you want to have a go at this yourself, the service manual can be downloaded from
http://www.mediafire.com/?m6ouftizois
Please report back if you need further help
Jan 24, 2009 | Epson Stylus Photo 810 InkJet Printer
EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
Aug 23, 2008 | Epson PictureMate (C11C556001) InkJet...
Cartridge Replacement
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C44 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40,42,44,60,62 service manuals, as far as ink pad replacement goes, they are the same.
May 09, 2008 | Epson Stylus C44UX InkJet Printer
Hi!!
Apr 19, 2008 | Epson PictureMate (C11C556001) InkJet...
Epson PictureMate 500 InkJet Photo Printer Logo
215 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
