Question about Zanussi Washing Machines
Zanussi ZWF14380W Washing Machine. Bits of grey shredded plastic in filter and oround door seal after every wash
Filter Blocked
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
  • 135 Answers
SOURCE: Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Posted on Nov 26, 2008
  • 1294 Answers
SOURCE: fitting of door seal on zanussi electrolux washing
Remove plastic clamp holding seal to cabinet and peel off the cabinet.push downwards on the seal close to the tub and the seal will come off - its just held by a spring round the periphery.
To fit new seal
Lubricate the slot which fits over the tub with washing-up fluid - essential
Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange.When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. this is quite difficult and you may need another pair of hands.
Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using in earnest. Use rinse to test as the water level is higher
Posted on Mar 12, 2009
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Posted on Jun 21, 2009
dancandoit
  • 436 Answers
SOURCE: WMA46 washing machine not draining, filter blocked
the filter is underneath on the pipe going to the pump, you wiull need to remove a hose clip.
Posted on Jan 04, 2010
All lights go to blinking when rinse or spinning
I will make a guess that either the outlet is blocked, the filter is blocked, the pump has failed. The most likely a blocked filter but soaps can accumulate and block the outlet.
Jan 25, 2015 | Kenmore HE2 Plus Front Load Washer
Where is the pump and filter situated in a fisher and paykel 501 washing machine
These machines don't have filters,
All lint is pumped out with the grey water.
Turn off power & water taps before you remove the pump.
To remove pump tilt machine back on a 45 degree angle
against a wall, locate the white plastic pump lock tab push out and turn pump anticlockwise.
Dec 03, 2014 | Fisher and Paykel Washing Machines
When i put fuel in tank it takes forever to fill up
check your canister filter is blocked or your filler neck has rusted out and blocked the vent line but 80% of the time the canister filter gets blocked take off the canister and you should see the filter full of dust or dirt
Apr 07, 2014 | 2001 Kia Optima
My Saeco Classico has problem. The pump is working
It sound as though the boiler is blocked by scale. May also be the coffee filter that's blocked. I am not familiar with this machine, but assuming that it's just a manual espresso machine, try running it with the filter handle removed. Any water emerging? If so, the coffee filter cup and/or filter handle outlets may be blocked. If there is only a small flow the boiler is almost certainly blocked with scale and descaling may cure the problem (do the first run with the filter handle off the machine. Next run with it on)
Oct 22, 2013 | Saeco Classico Espresso Machine
2008 honda shadow 750 keeps dying out
either a fuel blockage or blocked idle valve in carborator.
also possible air filter is blocked, ensure airfilter is clear and if
recently replaced ensure it is in the right way round
known case of airfilter being put in back to front and when it rained
the filter got completely blocked.
for quick check of air filter, remove it and try to start engine.
but do not drive without filter in as dirt can kill your engine for good.
I hope this was useful.
Sep 01, 2012 | 2008 Honda VT 750 Shadow
My Zanussi ZWF1658W washing mashine will not spin and drain the water it has a E20 error message on the display
I believe E20 is a blocked filter.
There should be a small door on the front of the machine almost at floor level.
BECAUSE THE MACHINE IS, I PRESUME FULL..... do this:
Unplug from mains
Tip machine backwards at about 45% so the water is not going to come gushing out of the filter when you remove it
Open the little door
remove and clean the filter
replace it
close door
put machine flat on floor agin
plug back in
start a cycle
Pray
Feb 26, 2011 | Washing Machines
Want to unblock all the incoming mails from a particular group???
goto ... > 'Options' and then > 'Block Addresse'
find the address you wanna unblock.... and click the 'Remove Block'
Oct 22, 2010 | Yahoo Mail
Door on washing machine is locked with e20 code
This particular code is used when the machine detects a pump problem or water draining problem. In this case, the fault would occurr just before attempting to spin. It turned out to be a blocked filter, accessible from the bottom front of the machine. so the best thing to do is clean the filter on the front of the machine open the flap and undo the filter water will come out so be ready for that. after it is cleaned and filter all back in and secure switch machine back on at plug and run cycle this should fix it. hope this helps.
Here are some error codes for future problems. E10 - not filling
E20 - not draining
E40 - door open
EFO - Filter blocked
Sep 19, 2010 | Zanussi ZWD1270 Front Load Washer / Dryer
403 Forbidden - Blocked by URL Filter how to unblock URL Filter??..
Aug 07, 2010 | Computers & Internet
Hi my hotpoint washing machine wont stop spinning for some reason any ideas what is wrong
Very likely that the filter is blocked. Because the machine senses there is still water present it carries on spinning but the blocked filter is preventing the machine emptying. Turn off the power at the plug. The filter is usually mounted at the front near to the floor. Unscrew counter clockwise and be prepared for some water to leak out. Clean the filter under a tap, it will probably looked blocked and then re fit. Select a short programme cycle and see if the fault is cured.
Jul 04, 2010 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
