Question about Bull Outdoor Products Bull Refrigerator, Stainless Steel Front Panel | 11001
Bull outside mini fridge, inside light on but not cold?? Turned cold dial and does not turn on. Door seal is good.
Temperature control panel
CHECK THE ON/OFF SWITCH ON THE INSIDE.
Jun 17, 2015 | GE Refrigerators
Why is my freezer not cold enough?
Check the freezer door seal is not leaky. Look for signs of moisture condensation along the door. Apply a thin film of Vaseline along door frame. This will make door seal stick better.
Also check there is no ice building up in freezer. This is a self defrosting fridge and built up of ice inside means warmer temperature. Lower the use of ice cubes from the ice maker to reduce load on compressor as this can effect freezer temperature.
Check freezer is not full of too many items causing reduction of air flow and hence reducing cooling effectiveness.
May 01, 2014 | Kenmore Refrigerators
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
Mini fridge not getting cold,freezer only gets cold?
If it's less then a year old you have a warranty, if it's older you are better off replacing the unit as direct parts are not available and subs would cost more that the unit.
Mar 24, 2013 | Haier Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
I have a mini red bull fridge...
Open up the compressor area and trace the wiring. The thermostat should be indicated on the wiring diagram, which should be pasted on the cabinet.
It just may not be obvious without a conventional knob, but it will have a thermal sensor tube- usually copper. It might be bonded on a sheetmetal panel inside the fridge. at least one wire to the compressor's mag starter will be attached to that thermostat to interupt power. It would be adjustable with a small flat bladed screwdriver. Clockwise should lower the temperature, and counter clockwise should raise it. To further complicate it that adjustment screw may be under a dab of red paint that used to anchor it.
Put a thermometer in the fridge to monitor the temp. While water will freeze at temps below zero, Sodas will not normally develop ice until below 30 degrees F and and beer will be fine to about 15 degrees F before it freezes.
Apr 02, 2012 | Refrigerators
Fridge side of side by side Frigidaire not working
your damper door is frozen or iced up and not opening up to let cold air in from freezer compartment,defrost it and make sure its dry,also check your door seal to make sure its sealing good and not letting in warm air that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
Water dripping onto floor. I believe it's from the
The cold air escaping from any gaps in the door seal is likely causing the condensation build up on the exterior of the fridge. You'll need to see if you can get the door seal (it's magnetic) to lay properly against the cabinet all around the door.
Sometimes a dirty seal will cause very small gaps that will let cold air escape, so give the seal and cabinet edge a good cleaning, making sure that the surfaces are clean and dry when done. Also, check to see if the seal is tight by using a dollar bill placed between the door seal and cabinet, all around the door. Any areas that you can easily pull the bill out should be checked for tears and/or cracks in the seal.
You might have to buy a nes seal if your's is badly damaged, but usually you can restore it to working shape with some patience and a good cleaning..
The other thing to check, since you didn't provide a model number and approximate age of the fridge, is to see if you have a "energy saver" switch inside the fridge section. This will allow you to turn on edge heaters to keep the condensation from forming on the exterior of the fridge. With the energy saver "on", the heaters are turned OFF, with the energy saver switch "off" the heaters are turned on. Heaters draw more power when turned on, hence the term "energy saver" being turned on, saves you money if you don't have condensation buildup on the exterior.
Jul 28, 2009 | Maytag Refrigerators
Refridgerator/Freezer will not get cold
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
May 04, 2008 | Magic Chef CTF2125 Top Freezer...
Outer back and side of fridge is very hot
Turn it off. If you keep running it, it will die completely fairly soon. Please feel free to jump to the end if you don't want a fridge science lecture - it might help you figure out the problem though. When a fridge/freezer runs, the condenser (all the tubes at the back) will get warm-hot. That is where the heat goes from inside the fridge. First thing to check; is there excessive heat to remove from the fridge/freezer? Check the door seals are ok - cold air falling out of a bad door seal can make a fridge both cool and warm a room at the same time - which obviously leads to problems Check that the lights inside actually go off when you close the door by pressing the switch that the door usually presses when it shuts, and checking that the door will press the switch as far as it needs to go. Second thing; Check that there is adequate ventilation at the back - remember the ideal situation technically for a fridge is to have the bit at the back outside the house in the shade like an air-con unit. pull the fridge a bit more away from the wall and try blowing a fan onto it. Clean gently with a soft brush any dust etc that is on all the tubes at the back - it can cause an insulating coat to form. If the dust is sticky and hard to shift, then gently use a soft paintbrush and warm soapy water. Third thing; When the amount of refrigerant gas in a fridge system is getting low (they all leak a tiny bit all the time - even without any fault) two main things happen: The fridge gas has a lubricant mixed in with it that keeps the inside parts of the system oiled. when the gas is low, so is the oil and you get the same effect as running a car with no oil - runs hot, then dies. The low gas has an effect inside and outside the fridge - inside, near where the gas first enters the evaporator (the plate in the fridge that gets cold) it will get extra cold. the compressed refrigerant evaporates too quickly - easy way to explain is that there is nothing in front of it in the queue so it runs through too quick. the same thing happens in reverse when the gas goes into the condenser at the back, the gas condenses too quickly making the back very hot. I think, from what you say, that low gas is the problem. Although it is not too complicated, it is illegal for you to do it yourself in most places for environmental and safety reasons - get any fridge repair guy and he can do it and check for leaks at the same time. Hope this helps, and is in time to save your fridge :)
Mar 28, 2007 | LG LRTP1231W Top Freezer Refrigerator
Bull Outdoor Products Bull Refrigerator, Stainless Steel Front Panel | 11001 Logo
206 people viewed this question
Top Bull Outdoor Products Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bull Outdoor Products Refrigerator Expert? Answer questions, earn points and help others
