Question about Refrigerators
The fan in my fridge is making a loud noise
How do i mend this
  • barry henning Nov 29, 2012
    ive already taken the back of once there was a big chunk of ice on the fan i took it all away but its all come back that was only 2 weeks ago what is causing this anyone know
  • Refrigerators Master
  • 4,654 Answers
You very likely have a defective door seal or the door to the ice chute is stuck open. This causes warm moist air from inside your home to be drawn into the freezer and freeze on everything. The solution is to stop the leaks cause by a defective seal or repair the door that is in the ice chute. Thanks, Sea Breeze
What is your model number?
Posted on Nov 29, 2012
  • 1462 Answers
SOURCE: Refrigerator making loud noise and fan: help!
take raer panel off inside freezer and check there is no ice build up which is hitting the fan
Posted on Jul 18, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 10 Answers
SOURCE: Loud noise from Fan and compressor
i have the same problem with mine. I took the back cover off at the bottom and the fan was going. get a scredriver and barely touch the center of the fan while it is on and if it stops making the noise then it is the fan motor. The bearings are getting ready to go out and it needs to be replaced.
Posted on Mar 24, 2009
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
sawdust46694
  • 398 Answers
SOURCE: Making a loud noise sounds like Fan
ok first i want you to pull your Refrigerator and look for a part of a loaf of bread or something else that has got inyour fan. hope this helps. if you don't find anything you may have a bad bearing on one of your fans. there are to fans one under the rear, and one inside the Refrigerator that you here when the door opens and closes pay close attn: to both!
good luck sawdust46
Posted on Aug 03, 2009
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Mar 22, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
