Question about EliteGroup Computers & Internet
Disable onboard video geforce7050m-m v2.0 - EliteGroup Computers & Internet
djnick989
  • 1067 Answers
SOURCE: disable video card
go in bios disable onbord use agp or pci exp setting plug in old way to change those in bios 1st then shut down plug into other
Posted on Jan 21, 2008
motaro
  • 449 Answers
SOURCE: How to disable onboard video on DC7600?
hello, sometimes if you disable on board VGA on your baord, the vga card will still not work well but i will tell you how to disable ooboard vga on your sytem anyway( got to the bios settings on your computer, select pheripheral setup and disable onboard vga.)
Posted on Dec 17, 2008
acdr
  • 1913 Answers
SOURCE: disable onboard video of presario 5105rsh desktop pc
u can disable the the on bord vga in bios
enter in bios then u see in ide or advanced vga disable it then save settigns .
Posted on Jan 29, 2009
  • 85 Answers
SOURCE: Disable onboard video on MS-7176 motherboard
if u using the Windows Xp do this....
(this method is for all hardware to disable or enable)
right click on my computer...
go to properties, then click on Hardware menu, inside this menu click on device manager, a popup menu will appear, now inside this menu u can enable or disable a device, now click on Display Adapter, inside this catagory u will find 2 devices, 1st one is your onboard video driver and the 2nd one is your card driver, here if u want to disable any one, just right click with mouse and disable it, restart will take effect well.....
Enjoy..
Good Luck
shafky
Posted on Jun 22, 2009
SOURCE: system does not see new video card
ok, finally got a vision tek radeon hd3650 to work on the gateway gt5082 machine. i tried like so many to disable video and add a digital card to run a new lcd display. had many problems and took several hrs of try and testing. funny thing is i was trying so many things out of frustration im not sure exactly what the final steps to get it working were. i would try this first. 1 remove the existing nvidia 6000 driver via device manager. shutdown the pc and unplug. 2. reboot and go into bios. set init video -> to pciex slot. Also change the escd option to reset extended info in bios. - this is what is causing the conflict with the interrupt assignments. 3 add the new video card in pciex slot and connect the digital monitor and cable. Fire up the pc. This should now work. Any questions just ask. cbc
Posted on Jan 12, 2010
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
Hi, excuse my poor english. How can I disable onboard video on a Lenovo M55e 9632AE2? Thanks in advance. Markus Brandl
There are two ways to disable the onboard video:
First Option:
When the machine boots up, watch for instructions such as "Press to enter setup, bios, configuration, ect." Within the BIOS setup should be an option to disable to onboard video. This can usually be found within an Integrated Chipset Features section or a Video section depending on your BIOS. Be careful though, messing with settings that you don't understand can affect your computer negatively.
Second Option:
Assuming you're disabling the onboard video because you have installed a video card, access the device manager by right-clicking "My Computer" and click Manage. Select the Device Manager on the navigation pane on the left, then expand the Display Adapters section. Right-click on your onboard graphics adapter and then click Disable and you're done!
May 25, 2011 | Lenovo ThinkCentre M55e 9632 PC Desktop
Problem with onboard video of a compaq sr2032x
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Apr 29, 2010 | HP Compaq Presario SR2032X PC Desktop
I am installing a Video-228pci-twin video card and need to disable the onboard video port. Jack H. Jholdridge@dennys.com
The best way to disable the onboard VGA is in the bios settings. So find in bios settings the peripherals or the video section and disable the onboard video.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 06, 2010 | IBM NetVista M42 PC Desktop
How to turn off the builtin video on QDI Winnex 1E motherboard?
Check your BIOS - there should be a setting in there to disable the onboard video. You shouldn't need to use a jumper to disable this.
Dec 18, 2009 | QDI Group QDI WinneX 1E Motherboard
Wie disabled man die onboard-graphic? Ich möchte eine Radeon X1600 mit 512 MB in den AGP-Slot einsetzen. How disabled the onboard-Graphic? I want use a Radeon X1600 in the AGP-Slot
Just plug in the Radeon video card in the agp slot and the system will automatically detect the new video card and disable the onboard-graphics.
Oct 30, 2009 | Computers & Internet
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
Enjoy..
Good Luck
shafky
Jun 22, 2009 | Intel Computers & Internet
Video controller disabling
That model server comes with onboard video. If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard. If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again. Hope this helps.
Aug 28, 2007 | IBM Netfinity 3500 M20 8657 Server
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Computers & Internet Logo
74 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
