Question about Kitchen Ranges
I have a Kitchen Aid Electric Range. Same problem as others(hit clean, stop/cancel and door remained locked) but not sure what type of lock it has. I can hear it trying to open. I've tried ever
Should I remove the cook top(what I'm thinking) or go to the back and start? Thanks, Mike
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 29, 2012
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Where are the relays that controls the oven on frigidaire electric range located
if range is self clean make sure door is closed, put on self clean wait about 0ne minute or so then cancel self clean . sounds like range is stuck in door lock Cheers
Dec 11, 2013 | Frigidaire FEF366 Electric Kitchen Range
My oven display says door locked. it isnt locked i can open it. BUT it wont unlock and allow me to set a temperature.
press in the door switch with your hand and set the clean cycle wait for the latch to make complete cycle then hit cancel while still holding door switch. if unit still says locked you may have bad latch assy.
May 12, 2011 | Frigidaire FED355 Electric Kitchen Range
I have a magic chef black electric stove and i never used the self cleaning but i cant stop the process the door is locked and the stove is getting very hot
Hello there:
Magic chef ovens and various other models of ovens have this no cancel feature this is due to the intense heatthat is generated during the cleaning process Normally if you press and hold the cancel button for 10 seconds this may cancel it out but the oven door will remain locked untill he temperature gets back to around 100 degrees see the cleaning temperature are almost around 600 degrees ok also you can unplug the oven and leave it set for at least 1 hour to allow the internal reset feature to reset the oven ok this has been known to take care of this problem too ok
Hope his is very helpful for you
Best regards mike
Oct 13, 2010 | Magic Chef CER3725AA Electric Kitchen...
heatman101
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Oven beeping, door locked F9 error
Have you tried to unplug the range for 5 minutes? That may reset the programming that is going on.
Nov 18, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
46 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
