Question about Philips DVP 520 DVD Player
Problem with Philips DVP520 DVD player
When I turn on the dvd player the "HELLO" message is displayed, but nothing more happens. I can press any button on the remote and on the dvd player, but nothing happens. It won't turn off when I press the standby button either. It used to first display "HELLO", then after a little while "LOAD" was dislayed. It's completely dead, except for the "HELLO" message...
techman
  • 3130 Answers
SOURCE: philips dvd player not working
Im sorry to tell ya that you did all the things I would have suggested, so it sounds like a system control problem or a power supply problem, and if its a good machine then maybe its worth you having a service person look at it?? Most dvd units are not worth it these days, unless there combos or recorders.. Sorry couldnt be of more help.
Posted on Jun 05, 2006
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
jyackle5
  • 8197 Answers
SOURCE: II can't unlock my philips
You need to make sure that you do the #8243 step
To change your DVD region settings try the following:
Turn on player with no disk inserted
Press "Open/Close" on the remote control
Press "259″ on the remote control
After enter the code 13893108520 again on the HOME Screen and the player will show region "0"
Now the buttons on the front of the player do not work anymore.... You will need to go to SETUP and click on RESET FACTORY SETTINGS....
Wait until the player restarts and now you can play all DVD regions
Posted on Feb 07, 2011
SOURCE: Philips DVP 3960 DVD player
fffffffffffffffffffffffffffffffffffffff
Posted on Feb 10, 2011
jdvillanueva
  • 2098 Answers
SOURCE: The last week the DVD player isn't working.
Hi kjones1021,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the optical lens can't read any disc. If you have a DVD Lens cleaner, play it to the unit. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc, this is because of the movement of the optical lens back-and-forth. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the spindle motor - Check the spindle motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Sep 09, 2011
I have a portable dvd and the screen is black with
This not good, you would be further ahead replacing the portable DVD player.
Mar 24, 2012 | Sony DVP-FX820 DVD Player
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
When I use the timer to record a TV show with my DVD-R155, unit locks up.
If you can afford it purchase a TIVO. I had a a video and dvd player and it drove me mad. This unit records 2 programs at once with just the press of a button.
you can watch tv at the same time. Also you can rewind situations on live tv to watch it again. Top unit. I am 73 and I have no problem using it. Love it!
Dec 07, 2011 | Samsung DVD-R155
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Unlock instructions for Toshiba dr570 DVD
Hello
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
Nov 03, 2010 | Sony DVP-SR200P DVD Player
Locked dvd tray.
Press Setup then the numbers 2 0 0 5 then setup and it should unlock
or
Display 2 0 0 5 Display
Dec 22, 2008 | Toshiba SD-K760 DVD Player
Only Power On light and Light on far Right come on
remove remote controll batteries and replace it , possibility get new ones
Apr 06, 2008 | Sony Blu-ray/dvd player BDP-S1
Philips DVP 520 DVD Player Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
