Seagate barracuda 7200.12 500GB From last week my hard disk is not detected in bios and also having ntldr missing pbm ..but earlier often system will hang and my harddisk cannot be detected i unplug the connection and plug it and select from bios it work normally ... But this Time i tried several times cannot detect my harddisk , have warranty for yet 10 months but need few important datas from harddisk .. Waiting for ur reply
  • 7 Answers
SOURCE: Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Posted on Jan 02, 2008
SOURCE: seagate freeagent 500g usb 2.0 beeps sound
I was plugging mine into a USB hub and getting a repeated beeping noise and nothing else. I then plugged it directly into my laptap USB ports and it worked fine. Seems to be a power issue.
Posted on Apr 26, 2008
SOURCE: system will not detect my Seagate ST3500641CB-RK 500gb external hard disk
My system is brand new, and completely protected with Macaffe, other USB drives are working fine, I checked Seagate External drive in other Vista and XP laptops, it is not detected in computer, as well I checked with even Device Manager, and UVCView.x86, it is not even showing as a USB device Connected.
Posted on Jun 07, 2008
  • 29 Answers
SOURCE: harddrive is not detecting bios
this problem is a product bug of seagate,and you can repair this bug when it is ok,but once it corrupt,then you cannot repair the bug by update it,you should first use some tools to repair it and then update the firmware of the drive,any questions pls kindly feel free to contact with me:honglake@gmail.com
Posted on Apr 28, 2009
SOURCE: Seagate barracuda 1tb hard drive not detected by
To determine if the drive is at fault, try it in a different computer. If it doesn't work, its now a faulty drive I'm afraid.
Posted on Jul 08, 2009
Hello sir jaizi here dear sir my segate harddisk not detecting its baracuda 7200.7 40 gb in this my all data my family pics my all stuff in that its working normall during browsing its become...
Seagate Barracuda 7200 fault:
Hello A.
Is the drive internal or external use?
Could be several reasons:
The head has crashed.
The driver is corrupt or missing.
The controller board on HDD has failed.
Data or power connector / cable loose.
Disk has overheated and failed.
Open the PC and check cables.
Check ventilation.
Is disk clicking or getting very hot?
If external, check connecting cables.
Download latest driver from Seagate.
If all else fails, take system to computer sales / service center.
They may be able to diagnose the fault for you.
The final option, but very costly, is professional data recovery.
Nov 23, 2017 | Seagate Barracuda 7200.7 40 GB Hard Drive
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
NTLDS missing when installing windows 7
Before tring to install Windows 7 I suggest you download (or your in law) from Microsoft a utility program that detects your hardware and tells you whether the system will support this RC version of Windows. Download "Windows6.0-KB947821-v4-x86 Update Readiness.msi" and run it on the system prior to installation. If your system is already damaged, install a base WinXP OS on it and try it. Good luck!
Aug 16, 2009 | Microsoft Computers & Internet
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
May 22, 2009 | Seagate Barracuda 40 GB Hard Drive
Boot won't read
Operating system not found. Check hard drive for loose connection power and interface. Reseat it to be sure (power cord disconnected and unit totally turn off before you reseat it).
Go to Bios setting check whether hard drive is been detected or re-detect it to refresh. If harddrive is not detected. Check again for loose wiring. If now detected, reboot it should until the end of operating system loading.
If it say again " requires sytem disk" ,corrupted OS --- repair or reinstall.
Apr 08, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Detecting problme
Hard drive was gone, you can send to seagate as RMA if it's within 5years warranty.
Feb 13, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate 20GB SATA hard disk not detected
Ok, look at the hard disks circuit board, look for rust or something suspicious.
Jun 19, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
