Question about Amigo Rd 3 Wheel Scooter with 33AH Battery Pack
Scooter will run at speed than **** and bog down.
Amigo Feista 1 scooter will run at speed than hesitate and bog down, after releasing lever it will again get up to speed and do the same thing after a little while. Scooter has new batteries and we replaced the pot 8 months ago and we just replaced the speed controller.(top cover with electrics) and that did not solve the problem. Any info would be helpfull.
  • 53 Answers
Time so see your local service center
Posted on Mar 16, 2015
SOURCE: Scooter battery problem
lots of things come into it driving up steep hills,useing lights,but you can get a larger amp hour battery witch make it last longer
Posted on Oct 11, 2008
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Posted on May 13, 2009
  • 1271 Answers
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
Posted on Jun 14, 2009
  • 1271 Answers
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
Posted on Jul 25, 2009
  • 177 Answers
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Posted on Jul 09, 2010
My 50cc scooter(chinese) hesitates at full throttle, almost like it wants to stall and then it kicks back in. Could this be a problem with the carburetor valve?
Hi, Randy and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Chinese Scooter Club View topic Hesitation On Acceleration
Why is the engine bogging under acceleration Suzuki FA50 Moped
scooter keep bogging down under throttle
1 HOW TO FIX Most common MOPED Carb problem
How to tune in scooter carburetor
Mar 24, 2017 | Motorcycles
Rascal scooter 245
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
Aug 23, 2014 | Electric Mobility Invacare Pronto M41...
Flat battery
the scooter will not move when plugged in, if you have a free wheel lever on the back to allow the scooter to be pushed make sure the lever is in the run position also have the batteries load tested
Mar 23, 2014 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Scooter runs but bogs down when given throttle 2007 triton vento scooter will run bogs down when given throttle
Make sure the air box is installed and the snorkel is on the air box and that it's in good condition. They don't run well or sometimes at all beyond idle without the air box. Could also be a clogged main jet or otherwise dirty carburetor.
Oct 26, 2013 | Motorcycles
My Amigo Classic hesitates sometimes.
you may have a bad motor contact amigo for a service tech. in your area 1-800-my-amigo
Oct 13, 2012 | Amigo Scooter Classic FD w/ batteries
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
May 12, 2010 | Electric Mobility 4 Wheel Heavy Duty...
When moving at top speed, my scooter hesitates at times until lately when it has slowed down to a crawl, then it will speed back up again. The charge meter is in the green area and I am consistently...
hi, that is a textbook problem related to the speed controller pot,
the pot is attached to the lever you move to go forward etc,
to be 100% certain trying moving the lever in the upwards direction while gong forward ? does it speed up ,a new speed pot required.
Oct 21, 2009 | Pride Value Line Revo Scooter 3 Wheel
Amigo Rd 3 Wheel Scooter with 33AH Battery Pack Logo
211 people viewed this question
Top Amigo Health & Beauty Experts
Tom Chichester
K McMurdo
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
