Question about Kitchen Ranges
No power to bake igniter
Broiler works, bake igniter does not glow. there is power to board leading to broiler. approx 12 v going to bake igniter
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 29, 2012
jessee007
  • 310 Answers
SOURCE: Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Posted on Jan 01, 2008
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
docjohn174
  • 943 Answers
SOURCE: BAKE SECTION OF OVEN FAILS TO IGNITE BROILER LIGHTS
Hi thanks for your question. its more than likely the glow bar you can remove it to check for a break in the heater, they are fragile. but it is a common problem i would change it. thanks the appliance doc. please rate, my answer, thanks
Posted on Oct 14, 2008
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
Viking oven broiler will not ignite
Your gas valve would be my first guess. Is this broiler (and bake ) lit with a glow coil or spark probe that goes (goes click, click, to light)??
If spark probe, you will have to replace either gas valve or spark board.
If glow bar lights the broil but does not glow, then replace glow coil.
Oct 18, 2013 | Dynasty DGRSC 48-6G Gas Kitchen Range
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
Gas broiler and bake over do not work, top burners work.
Could be a board problem or the safety valve. Hard to diagnosis without being there. I'm leaning towards the board if both both burners won't light...hope this helps...
Nov 30, 2009 | Kitchen Ranges
My Kenmore oven wont ignite. The broiler works
The problem is your bake ignitor. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The bake and broil oven features each have their own separate igniters and operate independently of one another. That explains why the broiler still works. They are, however, fed from the same gas source. So...the logical conclusion would be to replace your bake igniter (the no glowing is usually a dead give-away).
Replacements can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Prices can vary amongst sites, so shop around for the best price. The sites I provided to you, I found, tend to offer the best service and prices.
If you have questions along the way, or require addtional service, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
XL44 oven will not work
The fact that the igniter on the broiler actually begins to glow rules out your Electronic Oven Control (EOC) board. Usually when both oven features fail to work the EOC, or wiring, is the culprit. But...in your situation, the broiler igniter glows, but the bake igniter doesn't. You don't see this happen very often, but I believe you may have two bad igniters. The following link explains how to replace an igniter and gives you some theory behind how they operate:
Although an igniter glows, it still may be bad. This is usually dependent upon the age of the stove and the frequency of use. Usually, the bake igniter burns out first, because it is used more often. These igniters also grow weak with age. Which means, if they do not draw the required current necessary to open the gas safety valve, you will not have ignition. This is a designed safety feature that prevents free flowing gas from filling the oven box before ignition. I would recommend replacing both igniters to see if this corrects your problem. If you require additional assistance, or have questions, please let me know before you rate the solution. I hope this helps solve your problem.
Feb 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Oct 14, 2008 | GE Profile JGSP48 Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
AMytag MGR5775QDW Gas Range
I am assuming the BROILER works fine in the oven, right? If so, you may have a bad igniter for the BAKE manifold. It is common for them to wear out or become weak. Since the BROILER is not commonly used as much as the BAKE function, the BAKE igniter tends to wear out faster. You can check the igniter by removing the bottom plate of the oven, exposing the BAKE manifold. There will be a glow bar type igniter that begins to glow when the turn the oven on to preheat. If the igniter does not glow...a resistance reading will determine if it still good or not. It should read a low resistance if good. If the igniter glows, but still does not ignite, take a current reading. The igniter will have a current reading of 3.2 to 3.7 amps if good. In either case, if you do not get the desired readings, simply replace the igniter. There are two types of igniters listed under your model number:
Horizontal Mount - Part: #1034629 Price: $44.50
Vertical Mount - Part: #949510 Price: $41.70
This depends on how yours is mounted. Refer to your owners manual to see if there is a parts index listing. I hope this helps you. Post back with comments if I can assist any further.
CAUTION: Make sure you disconnect power from the range BEFORE connecting meter leads to the igniter leads. The igniter connector is usually found under the oven behind the lower drawer. In addition: if you DO purchase a new igniter, use care in handling it. The oil from your hands can potentially damage the igniter coil if you are not careful. This will result in a shorter life expectancy.
Jan 30, 2008 | Maytag MGR5750 Gas Kitchen Range
Kitchen Ranges Logo
130 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
