I need to install the fax option in an epson WF-3540 but it is telling me that the dial tone is failing
Therefore the machine told me to turn off the dial tone detection but anyway it is not working
  • 3 Answers
SOURCE: Fax machine not sending documents
A) Run the fax test on the printer itself to see if it's connected properly and has an active phone line.. HP All-in-one printers still make a dial tone sound even if they aren't connected to a phone line. To run the test 1)..Press the SETUP button. Press the down arrow button until "Tools" is highlighted then pres OK. 2) Press down arrow key again and select "Run Fax test" The printer will then print out the results. It will tell you if anything fails. If it does, the correct the problem it mentions. IF everything passes, then the problem is likely your cable phone line which is a "Digital" and Fax machines still use an analog signal. Here is what you can try to overcome the deficiencies in a cable phone system. 1) Set your fax speed to Medium 2) Turn your ECM (Error correction mode) OFF
To set your fax speed, Press the SETUP button again.. Press your down arrow again until you find "Advanced Fax Settings" and the press OK.. arrow down until you find "Fax Speed" and hit OK. Then choose Medium (14,400) and press OK This will take you to your previous menu (Advanced Fax setings).. Find "ECM Choose OK again.. Then choose OFF and press OK. Press the X button on your printer's control panel and then Retry your fax.. Hope this helps
Posted on Jul 21, 2010
  • 85 Answers
SOURCE: epson stylus dx5000 to be used as a fax
I'd suggest unplugging the unit completely, and then removing the printer from the installed printers by uninstalling it (right-click on the printer icon and then DELETE), and then going through CONTROL PANEL -> ADD REMOVE PROGRAMS and remove all software related to the printer or EPSON. Then reboot.
Then download the updated software and driver package from:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cwZFv9U002FAWw01BceF4s0u5BqhtAJNNMU002F2D8U003D&tc=6
...and follow instructions for a clean install and set up of the unit.
Uninstalling the old software and drivers and removing the printer is important to be certain the new installation will work without confusion.
Good luck...
Posted on Nov 17, 2007
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
SOURCE: fax connection problems - no dial tone
are you sure the jack is working? the cord is ok, and plugged into the "line" port on your machine?
Posted on Mar 01, 2009
SOURCE: Cannot receive faxes on Samsung SCX-4521F
I'm not sure if I can help you or not, but I do have a suggestion or 2, that may help isolate the problem.
The solution I gave you initially, is the usual culprit for the situation you are experiencing. If the machine can "send", then "receiving" is not normally a problem, as long as the reception settings are correct. You said that "sending works fine"?
Since you have multiple faxes, you might try swapping the locations, or at least try the Samsung in a known working environment, to see if it behaves the same. If it works on another line, then try the other fax on the "Samsung" line.
That's all I have to suggest right now, but I'd be anxious to hear if there is any change.
Posted on Apr 28, 2009
How to fix epson wf-3540 error code 0xFA all it tells me is to unplug then plug it in and still dose not work
Check the cartridges. Remove the cartridges and re insert it. sometimes bad contacts can causes such problems.
for more details check the link bellow
http://electro-medical.blogspot.com/
Dec 26, 2015 | Epson WorkForce WF-3540 Wireless...
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
0x05 epson error code
What us the result of the error? what are you doing to produce the error?
Sounds, offhand, like a driver failure of some kind (ADF??)
Jul 19, 2015 | Epson WorkForceR WF-3540 All-in-One...
Epson wf 3540 paper jam in adf and the mechanical system keeps on grinding in there. Is there a video somewhere on how to open the ADF and align parts in there. I know how to open the adf from the sid
please try the below link all the steps to be followed carefully.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=FAQ&oid=232591&foid=254073
Jan 17, 2015 | Epson WorkForce WF-3540 Wireless...
How do I reset wf 3540 printer to factory default to eliminate the driver updates software problems
Turn it off, if you can. Then unplug it from the wall and wait for it to shut itself down. Then plug it back in, wait, then push the start button.
It should have recycled itself.
Aug 15, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
How do I print envelopes on the Epson WF-3540 printer
Envelops can be printed per the software such as microsoft office. Depends on the program you use but if the software you use has this somewhere. sorry but it is a setting.
Jul 29, 2014 | Epson WorkForce WF-3540 All-in-One InkJet...
I can't change the print quality in excel for my Epson WF 3540
A driver component is missing meaning not installed good or not all the drivers for printer is installed.
Jan 30, 2013 | Epson WorkForce WF-3540 All-in-One InkJet...
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
357 people viewed this question
jasbo
jasbo
