Question about Samsung Syncmaster 940BW LCD Monitor
I bought a new computer and it isn't recognizing my monitor (blank screen)
  • 67 Answers
Most monitors use software that you load onto the new computer. Look for a disk or hook up the old PC to download it.
Posted on Jan 10, 2009
Dell inspiron 560 problems
chek your video card it my be going out
Apr 30, 2013 | Dell Inspiron 560 PC Desktop
Bought new visionquest 19" monitor,
Nope it isn't defective. You don't mention from your question if you bought a LCD type or the CRT type of monitor. But I think you bought a LCD monitor right? My question here is where do you connect it? From the graphic card or in the onboard vga of your motherboard? How old is your graphic card/onboard vga? That is always the problem of an old graphic card because it can't release more pixels that's why it says out of range. Connect your old monitor it will work because it can support your graphic card/onboard vga. Buy a new graphic card with a specification that will suit to your motherboard and to your new monitor before it become a money waste
Aug 01, 2011 | Computers & Internet
White screen, power switch not functioning.
Unplug it, reset it. Did it come with install disk? Try running that with your old monitor. The system may not recognize it as plug and play or the monitor may be defective. Call Tiger Direct or whoever you bought it from for support.
Jun 24, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Blank screen
Disconnect the monitor , from the computer, switch the monitor on , if you have some kind of Dell self test box running on the screen. The monitor is OK . The problem can be with the video card or resolution settings.
Also, try connectin the old monitor you had hooked up with the system to check ,if you see anything
Mar 14, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Kogi l4ax monitor (black screen)
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to fix it. Hope this help!! If anything I can help you with, feel free let me know.
Thank you,
Mar 06, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Notebook labtop screen blank
Something very simple....have you tried fnc+F7 (maybe F5) to change from monitor to lcd screen?
Oct 21, 2007 | IBM 05K9567 14.1 in. Flat Panel LCD...
Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
Oct 19, 2007 | HP Pavilion F1703 17" LCD Monitor
No Display
I have the same problem - the blank/black screen and blinking green power light. The speakers on the monitor work (I can hear the start-up sound that Windows makes), but the screen is blank. We bought the monitor on Halloween Night 2003 at Best Buy and had zero problems to date...except for last night. The Best Buy gang told me this afternoon that it was an internal hardware issue. I called the manufacturer and the tech guy confirmed the problem by saying he was almost positive it was the internal "inverter board" - which means you have to send it in to get it fixed. I guess this is a fairly common problem with these monitors by the way he made it sound. So, that's a $70.00 deal (service, parts, labor, and shipping back to your house) - that is, if there are no other issues with the screen itself - then the cost goes up. So by the time you pay to send it to them and then pay them to fix the board - it looks like you're better off buying a new flat panel monitor. Yikes. Anybody else with any suggestions - other than buy a new one? Thanks!!
Oct 19, 2006 | Mag Innovision LT776s 17" LCD Monitor
Open Questions:
See all Samsung Syncmaster 940BW LCD Monitor Questions
Samsung Syncmaster 940BW LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
