Question about Refrigerators
FRIDGEADARE IS MAKING VERY LITTLE ICE , FREEZER IS 0 DEGREES AND WATER IS COMING IN
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
  • mrgroovie
    mrgroovie Nov 30, 2012
    PLHT219TCBE.iT'S BEEN ALMOST 24HRS AND BASKET NOT EVEN HALF FULL. WHATS THE LITTLE SCREW THAT HAS PLUS AND MINUS AND YOU CAN ADJUST IT UNDER THE COVER.
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
  • 13 Answers
SOURCE: I have a Samsung SR-S2028CSS
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Posted on Apr 08, 2008
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
aasc
  • 1606 Answers
SOURCE: freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Posted on Sep 27, 2009
MY ICE MAKER WORKIN FIND WHEN PUT IT ON THE FIRST TIME. AFTER MAKING THE FIRST CUBS IT REFUSE TO FILL THE ICE BUCKET WITH WATER.WHEN I RESET IT THEN IT WILL WORKING AGAIN.
Water freezes at 32 degrees F, but an ice maker will only cycle at 13 degrees F or below... What is the temp of the freezer? Should be at 0-10 degrees F during normal operation.
May 27, 2016 | Refrigerators
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
I just replaced the ice maker for a Maytag refrigerator (M# MSD2756DEW), but the harvest cycle is 4 hours or more per harvest. Is there a way to increase the cycles or is there something wrong with the...
there is really no adjustment on those types of icemakers, your freezer temp should be a little colder - 0 to 5 degrees F . This will speed the process a little.
Aug 24, 2011 | Refrigerators
My frigidaire gallery french door refrigerator is making ice very slowly. the water is coming out fine. It is only 4 weeks old. i got solutions from frigidaire from the valve to the water filter. Any...
The theory to making ice is temperature, water, and ice mold to function. What are the temperatures inside the freezer currently. It must be below 15 degrees to function and prefer the freezer to be at 0 degrees to product effectively. Are you ice cubes solid or hollow? If hollow you can jam the ice inside the ice maker causing slow production. Rare to have a water valve problem this young be is possible. I would look at temperatures first than cycle time to determine the next step. In a perfect world, your unit should drop ice every hour to and hour and a half.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | Refrigerators
Wsf26c2exf ice maker not making enough ice.
CHECK THE WATER PRESSURE AND FILTER,ICE MAKER PROBABLY IS NOT GETTING ENOUGH WATER,ALSO CHECK IF THE FREEZER HAS A GOOD TEMP 0 TO 10 DEGREES..
Jul 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have plenty of water and pressure coming to the refrigerator from the house, but when we try the in-door water dispenser, the water comes out at a slow trickle. Ice is not making. We installed a new...
whirlpool has had frozen waterline issues whats temp in refrigerator and freezer make sure refrigerator no colder that 37 degrees and freezer th 6 degrees
Jan 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water is not coming out of the dispenser. Frig is
Good day,
4 hours is no ware enough time. As well, turning the freezer to a warmer temperature does little, since you're only changing it by a few degrees.
Forcing anything thru that tube, if it's ice can result in a difficult and expensive repair.
No body likes this, but shutting the machine off (unplugged), leaving the freezer door open with a floor fan blowing on the inside of the door is safe, but inconvenient.
Nov 15, 2009 | Frigidaire FRS23R4A Side by Side...
Not getting cold enough to freeze popsicles but is making ice cubes
water freezes at 32 degrees. ice cream needs to be below 0 degrees to remain firm. your freezer is nort cold enough. ;)
Aug 12, 2009 | Freezers
Frige is cold, freezer is cold & freezing . . . Ice maker not making ICE.
Hi: As we don't (as in I) know the actual temp. in the freezer, this is a simple and free try. Cold is cold. The temp in the freezer has to be 0 degrees to make ice. They are thermally protected. A good guess for temp. is your ice cream. Is it rock hard? A lot of refrigerator thermometers are inaccurate. Just try setting your freezer colder. Ignore human nature and don't check the freezer every 30 Min's. You will never get to 0 degrees. I hope this helps, Jeff
May 31, 2009 | Refrigerators
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
