Question about Coffee Makers & Espresso Machines
Owners manual for cimbali m30 bistro 2
Cimbali m30 bistro 2
2 Suggested Answers
  • 18 Answers
SOURCE: La Cimbali Owners Manual Wanted
Operators manual only describes how to install and set up. The Technician's manual is translated from Italian and is purposely vague. (Cimbali wants you to go to tech school). Suggest you ask for a annual preventive maintenance from your local service Cimbali dealer. You may need an overhaul/de-scaling which will be very expensive (+$1,000) in labor and parts. (mostly labor as it takes us about 40-50 hours per machine.) Hopefully you just need to change the worn parts in both groups and a vacuum valve. Good luck!
Posted on Feb 10, 2010
La Cimbali M30 Dosatron Technical Manual
Customer can perform daily (hourly) cleaning and back flushing. Which really helps keeping everything working smoothly. Even if the back flushing is done hourly without cleaning powder helps. The best practice I've observed was clearing group(s) after each dosing. (when customer's order is done)
Other function adjustments may require a service key and tech.
ukeboy57
Oct 17, 2013 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M30 Dosatron Espresso Machine dosing buttons not functioning, how do I fix?
These are membrane pads that do require a full replacement as they are all attached on a sheet. Some of the optional buttons are on separate pads but still grouped together.
check cimbali.com (for current USA contact)
Dosing can be change though some machines may require a service key.
you can also try (which is closer to your time zone)
Hawaiian Paradise Coffee 808) 682-4422
ukebo57
Jan 25, 2013 | Espresso RMI La Cimbali Espresso Machine
La cimbali m31 bistro
It sounds like one or more of your gaskets has failed it depends where its leaking and steaming from.
I find a parts list is helpful in identifying where the problem might be the best I could find on the net for yours is a austrralian website that has on line parts diagrams apparently a lot of the parts are used in a number of their machines the link is
http://www.coffeeparts.com.au/cimbali/cimbali-spare-parts-1
May 31, 2012 | Coffee Makers & Espresso Machines
I cannot find a user manual for my La Cimbali M50 Dolcevita. Can anyone help?
The M50 manual comes in 2 styles; Install and operate which will usually come with a new machine. The technician's book is only available to techs. Though the tech's book is in multiple languages there is certainly a lot of cross translation issues. Cimbali suggests attending their technician's work shop (in Italy) though if your lucky you may be able to spend some quality time with their USA distributor/rep. The M50's, M1,2,3,5 etc. are more complicated than the rough and tumble M30's. It would be wise to have a tech service your machine for the first year and have your own repair guy watch what they do. You can easily master the simple change out. More important is to perform the daily tablet cleaning and when time permits; perform a "no tablet flush" another words; run the cleaning cycle with out the tablet. This flushing helps keep the coffee drips clear from the brewing chamber and spout. Keep in mind that the flush cycle takes and average of 8 mins so perform it during a slow period. ukeboy2@yahoo.com
Apr 28, 2012 | Espresso RMI Coffee Makers & Espresso...
La cimbali m32 bistro overheats How do i fix this?
Hope it would help by follow the step on this link: http://www.hwl.dk/product-images/mespres32_man.pdf
Apr 14, 2012 | Coffee Makers & Espresso Machines
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
How do you change the dosage time on a Cimbali Bistro espresso machine
You can do it one of 2 ways, if the machine has a display then you can go through the program mode by removing the face cover on the display and pressing the programing button then navigating to the dose setting menu, then select a button and change the numbers there. Note the numbers are not ounces rather flowmeter cycles.
Second way is to hold down the stop button for 8-10 secs you will notice the lights flashing and you will hear a faint beeping every second, press the button to program then hit stop when you get thew correct volume, when done with all buttons hit the stop again.
Oct 06, 2009 | Espresso RMI La Cimbali Espresso Machine
I'm looking at a m30 Dosatron D'Italia coffee machine.
Get it. It is hard to find a Cimbali on the market for a great price. The M30 might be about 6-8 years old. There is nothing on there that you cannot fix yourself.
Jun 16, 2009 | Espresso RMI La Cimbali Espresso Machine
Mar 13, 2009 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
428 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
