Question about Gemmy Life-Sized Animated Santa
How do i repair the gearbox on a gemmy animated dancing santa?
Gemmy automated sante will sing and his mouth and head will move but his arms and hips do not move. how do i repair it?
SOURCE: Gemmy Santa Bear mouth does not move
The repair listed is just the start. You can, with a lot of careful work, remove the bottom of the mouth, but your work has just started. You will then have to remove the rod that holds the mouth rod to the mouth slide lever "spine". It has a small spring at the top and I found it easier to disconnect the spring prior to repairing the unit. It is glued in quite well so I suggest a Dremel tool to cut the sides off which you will enable you to remove the rod. Then you can remove the head from the spine without difficulty. Now you will see that the problem is as stated, the string that pulls the mouth open has separated from the motor shaft. The cause of this problem is that the grease that the mouth slide lever rides on has migrated to the string, and then, softened the glue, which allows the string to separate from the motor shaft. Now, clean the shaft and replace the string. The original string is nylon. You should use similar material, NOT cotton string or a rubber band. You can't use the old string as it is soaked with lubricant. Use a good super glue to bond the new string to the motor shaft. Next, test the unit to make sure that the mouth slide lever operates properly. Reassembly of the unit would be: remount the head to the neck, then reattach the mouth rod to the mouth and then reattach the mouth and rod to the mouth slide lever.
Posted on Aug 29, 2009
SOURCE: I have a lifesize grinch
if you have the same on as I do, gently pull off his head - there is a large dial that you turn to unlock him into the standing position.
good luck
Posted on Dec 18, 2010
Testimonial: "Thank you so much,I would never have figured that out..... Peggy !!!!!!!!!"
SOURCE: Our Singing Bing Crosby Santa doesn't move his
I have had the same trouble. I had to take his head apart and there is a string that is attached to the motor that works his mouth. The string has come unattached and needs fixed. The head is put on with a type of staple around the neck.Take them out and you will see what I mean.
Posted on Jan 16, 2011
SOURCE: I have the 48" gemmy singing, dancing santa. We
I have the same problem. Ever find an answer?
Posted on Nov 28, 2011
SOURCE: gemmy 5 ft animated singing dancing santa claus christmas life size and it as stoped working, can you help, please :(
i need a cord for my singing santa
Posted on Nov 24, 2012
I have a 5 foot singing Grinch that I cannot get into the standing position. I have pushed down on his shoulders and releasing gently. I've searched for a dial on Neck to turn and cannot locate
I have a 5' Singing Dancing Skeleton by Gemmy Industries
ebookss.holding.no-ip.ca/F/support/t6410955-5_singing
I have a 5 ft tall singing dancing santa claus that was from Walmart. ... christmas(Gemmy 5 ft Animated Mr. Grinch Singing Dancing as Santa )who I cannot get out of ... My Gemmy Singing, Dancing Santa won't spring up into standing position.
15235022 Penguin won't dance - Document Download
codigo.no-ip.net/F/support/t15235022-penguin_won_39_t_dance
... you turn to unlock him into the standing position. good luck , I have the same problem. ... I have a 5 ft tall singing dancing santa claus that was from Walmart. ... 5 ftAnimated Mr. Grinch Singing Dancing as Santa )who I cannot get out of the ...
I have a lifesize grinch who stole christmas(Gemmy 5 ft - Fixya
Dec 01, 2015 | Toys
My gemmy santa claus stop dancing and head moves one way
Here are 2 reasons why he would have stop dancing 1.the motor inside the body might be dead 2.a wire came off of the motor for the head could could just be the motor is dying
Jul 08, 2014 | Gemmy Life-Sized Animated Santa
THE JAMES BROWN WILL SING AND MOVE HIS HEAD BUT HE CANT DANCE
Could he ever dance?
if he could take him to pieces and look for a broken bit.
Alternatively live with it and get on with your life
Jun 17, 2014 | Gemmy Life-Sized Animated Santa
Santa moves and mouth moves but no sound.
Hi there my Santa sound is coming on real low then goes off
Nov 18, 2013 | Gemmy Life-Sized Animated Santa
I need an instruction manual for gemmy lifesize singing and dancing santa
The shoulder thing worked! thanks so much!! i was all over that thing!
Dec 10, 2012 | Gemmy Life-Sized Animated Santa
I need a new power plug for my 5ft singing dancing santa
there are so many out lets ask on google chrome according to your city and country.
Dec 13, 2011 | Gemmy Life-Sized Animated Santa
Dec 13, 2010 | Gemmy Life-Sized Animated Santa
Our Singing Bing Crosby Santa doesn't move his mouth any longer, but his head and microphone still move while he's singing. Can we get his mouth repaired somewhere????
Dec 14, 2009 | Gemmy Bing Crosby Big Head Doll
Gemmy Life-Sized Animated Santa Logo
114 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
