Question about Maytag Centennial MVWC6ESWW 4.0 cu. ft. Top Load Washer
My Maytag Centennial washer won't fill up with water. When I turn the know to the spin cycle it spins so the motor works.
It won't start a new load and doesn't fill with water.
  • 36 Answers
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
beltronic205
  • 1466 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
My maytag centennial washer wont start and fill with water, spin cycle works fine.
I would recommend checking all your hoses and make sure your water is turned on.
Aug 24, 2014 | Washing Machines
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer wont start, it will spin but will not begin the wash or start to fill
It won't wash till the water fills to the point of tripping the water level switch. Check your screens for clogsthemobilian_3029.jpg
Service manual and more
Sep 22, 2011 | Maytag Centennial MTW5800TW Top Load...
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Maytag Centennial MVWC6ESWW 4.0 cu. ft. Top Load Washer Logo
626 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
