Question about GE DVL223GB Gas Dryer
SQUEEKING AS THE DRUM TURNS
HELLO,
I HAVE A GE #DPSB613GDOWW GAS DRYER.
THE SQUEEKING IS REPETITIVE AS THE DRUM TURNS AND
THE SOUND COMES FROM WHERE IS EE THE FELT IS MOUNTED AND THE DRUM PASSES THROUGH THE FELT. I HAD THE TOP OPEN AND THE LEFT FELT IS INTACT. THE RIGHT LOOKS LIKE IT IS 80% GONE. AS WITH THE CARS I'VE OWNED, THE PROBLEM NEVER IS PRESENT AT THE RIGHT TIME.
THIS EXPERIENCE IS THE SAME ON DRYERS AS THE NOIZE WASN'T PRESENT WHEN I RAN THE MACHINE WITH THE LID OPENED UP. IT LOOKS LIKE IT IS EASY TO REPLACE BUT INSTRUCTIONS WOULD BE NICE AS I'VE NEER DONE THIS BEFORE. COULD THIS HAVE BEEN CAUSED BY SWITCHING TO HIGH HEAT? NEVER USED THAT SETTING UNTIL 2 WEEKS AGO AND THIS SOUND HAS BEEN GETTING WORSE. i HAVE CLICKED ON THE FREE NOTE. IS THERE A CHARGE FOR THIS ANSWER?THANKS FOR YOUR HELP. DEAN
  • 193 Answers
I believe your problem is the rear drum pivot and bearing.On high heat you would hear i squeak per rpm
Posted on Sep 29, 2009
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
What is the loud squeeking sound from my dryer?
bad bearing worn belt, bad or drum pads
Jul 05, 2014 | GE Dryers
DRUM TURNS THERE IS NO HEAT
Check out my tips and tricks for gas dryer heating problems. Click on my username and scroll down til you find it listed on my profile.
May 16, 2010 | GE DBXR463GB Gas Dryer
Gas dryer works, but does not heat
Hello there:
here is a discriptive way of trouble shooting the dryer and it lists the common components that will normally fail if the element has not failed first
Gas Dryer Diagnosticsgasdryerguts.gifThis picture shows the main parts of a gas dryer's burner systemthat can fail. Understanding each component and it's failure mode canreally help diagnose a problem with a gas dryer.
Ignitor failure: The drum turns but the igniter doesn't glow, thereis no clacking sound as the gas valves open and there is no flameignition sound.
Radiant Sensor failure: The drum turns but the igniter doesn't glow,there is no clacking sound as the gas valves open and there is no flameignition sound.
Gas Valve Solenoid failure: The drum turns and the igniter glows andgets turned off but there is no clacking sound as the gas valves openand there is no flame ignition sound.
And another component failure to be aware of, but that's not shown here, is the operating thermostat:
Operating Thermostat failure: The drum turns but the igniter doesn'tglow, the gas valves don't open (there is no clacking sound) and thereis no flame ignition sound.
And here's a picture of other components to ohm out if you're getting no heating at all:
Nov 21, 2009 | Hotpoint Dryers
My GE gas dryer makes a loud squeeking noise running
WE 3X 75 is the part number you need. Take a look at these repair pix
Sep 09, 2009 | GE Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
GE DVL223GB Gas Dryer Logo
112 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
