Question about RCA F32450 32" TV
Tv on but cannot use remote
Tv on but remote doesn't work, numbers 1 thru 99 keep flashing in the upper right hand corner. Also when you press menu it just flashes but doesn't stay. Menu on tv panel doesn't work either. It's like the TV is stuck in some sort of loop.
  • kim1061 Jan 10, 2009
    yes I did but it didn't help.
  • 837 Answers
Have you tried unplugging it for at least 5 minutes?
Posted on Jan 10, 2009
How do you hit the menu 6-1-2-
joy raley,
Press 'Menu' on the upper left corner of the remote, It's a small button with a few bars in it, then press those numbers on the number pad. You can also navigate to the options in the menu themselves.
Let me know if you need additional assistance!
Tommy Faust
DISH Social Media Representative
Oct 22, 2012 | DISH Network DVR-625 DTV Receiver /...
Tip
Service menu codes sony
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control:
# Turn the TV off.
# Press {DISPLAY} {5} {VOL+} {POWER ON} buttons.
or
Press {DISPLAY} {5} {POWER ON} buttons.
# The Service Menu will be displayed.
# Use numbers {1} and {4} to select the item to adjust.
# Use numbers {3} and {6} to adjust the value of the data.
# Press {MUTE} then {ENTER} to save new settings.
# The words "WRITE" in red will show up in the upper right corner if saved.
# Turn the TV off to exit the service menu.
on Apr 29, 2015 | Sony Televison & Video
I have a 2001 sony 53' rear projection tv model #KP-53HS30. It seems has a wavy section on the upper left hand corner and lower right hand corner of the screen. All the bulbs are working fine but seems...
Try this. The follow was found on tv-forums dot com by Zyntar...
There is a secret service menu to converge the Sony KP53HS30.
Caution: Be careful, there are many settings that can be tampered with. Some may be hard to undo.
Procedure: (use the remote control for these steps unless noted)
1. Turn TV off with System Off (under flap on remote)
2. Press: Display, 5, Volume +, then Power. If successful, service text will appear on the screen.
3. Use 2 & 5 to select the PJE Category.
4. Press 9 to get to fine convergence adjusting.
5. Press 6 several times to get the convergence screen of choice. I like the grid.
6. Use the remote's arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color. Press 3 to change color to adjust. When done, press center of joystick again.
Note: Try to keep the grid even and squared up.
7. Repeat steps 5 and/or 6 for all parts of the screen that need it.
8. Once done, you need to save your settings. Press: Mute, Enter. Then on the TV, press "Flash Focus"
9. Turn off power.
TV is ready to use.
Oct 20, 2010 | Sony KP-53HS30 53" Rear Projection...
Remote will not work on #2 TV satilight
It could be the distance the remote is from the antenna. Try going to the receiver and pressing the guide button on said remote. Go back to TV 2 and see if it is up. If not go back to tv 1 and with TV1 ON AND TV1 REMOTE IN HAND press MENU-MENU. You will be able to see the remote addresses for the remotes toward the bottom of the page. With TV2 remote in hand press and hold the SAT button in the upper left of the remote until all buttons across the top illuminate. Now press in a two digit number between 2 and 15. Press the pound sign and the SAT button will flash thrice. Now press record a few times until you see the TV2 icon on the screen blink and the address is the same as you keyed. Exit out of the menu with TV1 remote. Go to tv 2 and try. You should be good to go. If your remote worked when you brought it close to the receiver you need to relocate the antenna on the back of the receiver to the room TV2 is in.
Thanks for using Fix Ya.
Feb 08, 2010 | DISH Network ViP622 DVR DTV Receiver /...
The receiver is not reading control remote No.2. the control works, but the receiver does not respond to it. Could it be the antena?
It could be the distance the remote is from the antenna. Try going to the receiver and pressing the guide button on said remote. Go back to TV 2 and see if it is up. If not go back to tv 1 and with TV1 ON AND TV1 REMOTE IN HAND press MENU-MENU. You will be able to see the remote addreses for the remotes toward the bottom of the page. With TV2 remote in hand press and hold the SAT button in the upper left of the remote until all buttons across the top illuminate. Now press in a trwo digit number between 2 and 15. Press the pound sign and the SAT button will flash thrice. Now press record a few times until you see the TV2 icon on the screen blink and the address is the same as you keyed. Exit out of the menu with TV1 remote. Go to tv 2 and try. You should be good to go.
Dec 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Samsung DVD-VR375 - can't chage from region 1 to region free
I used this and it worked for me!:
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jun 20, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
LOCKED DVR
I just bought the CH-DVR 1600 @ Target. This is just a temporary workaround to enable playing of region 2 DVD disks (don't have other regions but believe it will work also), until the real regional unlock is available.
1. Insert the region 2 DVD disk and close the tray.
2. Wait for the "Wrong Region" popup to appear in the upper-right corner of your TV screen.
3. The display on your DRV reads "STOP" at this point and the "Wrong Region" popup has disappeared.
4. Press the number "1" button on your DVR remote and a small input popup will appear in the upper-left corner of your screen.
5. Do not press anything else and the DVR will accept this entry as a chapter # and proceed to this chapter to start playing the movie.
NOTE1: The DVR runs in a somewhat restricted node, e.g. the DVR display still reads "STOP" and some remote functions do not work, such as "Menu". The input numbers correspond to the chapters on the DVD disk, so you can experiment and get to the menu once you hit one of the extra feature chapters with a "back to the menu" link on it.
NOTE2: I’m anxiously awaiting the real unlock sequence, as I tried most of the old ones posted here, none seemed to work.
also try this
-Switch player ON with no disc in the tray. Close tray and press MENU, 1, and 9 on the remote control. A menu should appear with the Region Option. Highlight the Region entry and press ENTER on the remote. Type in the Region you want. (Put 0 for code free) Press ENTER again to confirm choice. Press OPEN/CLOSE TRAY button and put in movie.
Mar 31, 2009 | Cyberhome DVR 1600 DVD Recorder
Can't play region 2 dvd's on my player
Newer DVD224 is actually DVD-224ss - small print on front of manual. There are two possible hacks:
DVD224SS (This worked for me)
1. Open the DVD tray
2. Press STOP button on the remote control
3. Press 70
4. Press MENU
5. Use the numeric keypad to select your region code number (0 – 6).
OR
DVD224 (224SS)
2. Press STOP button of remote control
3. Press the digit number buttons “2008” of remote control.
4. Press MENU
Region code will appear, select your region code number.
Jun 22, 2008 | Coby DVD-224 DVD Player
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA F32450 32" TV Logo
195 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
