Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The washer stops before the rinse cysle
The washer will start and go through the wash cycle and just before the rinse cycle it will stop. I can hit my fist on the top of the washer and you will hear the dial start clicking and the washer will start back up with no more problems. I have sprayed WD-40 behind the dial and that has not made a difference.
    Scholar:
  • 60 Answers
That sounds like your lid switch. This switch is located on the top. Raise the lid, Looking down at the washing machine it is the little hole. If you push it down with your finger on mine it's grey in color. The problem is that the switch is not getting pushed down far enough. if you pull it down manually with your hand a little farther you should hear it click over and the machine might scare you as it starts up into the rinse cycle. You can purchase them pretty cheap online at any applince site.
Posted on Jan 11, 2009
Why does my washer stop after the rinse cycle and doesn't advance to the spin cycle?
only a guess but sounds like the control board or the timer is going bad .stating make and model usually helps
Feb 02, 2016 | Washing Machines
Why won't my front load washer fill in wash cycle unless I use rinse/cycle first?
either the motor brushes are worn most probable or the outlet presure switch has an issue {used to see if there is water still in the drum by the control logic}
Nov 28, 2014 | Washing Machines
Washer only works20 seconds then stops
Maybe at 10 years+ of service it is time to stop dumping money into repairs and buy a replacement.
Mar 14, 2017 | Roper Washing Machines
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Will not pump out water after rinse cysle
if water pumps out fine after wash cycle, this means it a control panel issue, may need to be replaced
Sep 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
