Question about Exercise & Fitness
What kind of lube should be used for the bearings and walking belt of a proform 625 treadmill?
    Top Expert:
  • 12,223 Answers
1) for deck belt use 100% silicone LUBE
2) for bearing use WD-40 Or similar.
God bless you
Posted on Nov 30, 2012
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
  • 3230 Answers
SOURCE: The walking belt on my
You can usually find the screws to tighten the belt at the back of the machine - but be careful not to tighten too much. A quarter turn may be all that is needed. A gentle tug will get the belt back into alignment if it is askew. Remember that if you have trouble tightening or realigning the belt, you should seek advice from the manufacturer or the fitness store where you bought your treadmill exercise equipment.
Most new treadmill machines do not require belt lubrication, and therefore you should only lubricate your belt if the manufacturer specifically recommends it. Most of the manufacturers who do recommend regular lubrication sell kits with instructions and all the equipment you need to make quick work of the task.
Post further comments for more help or information.....
Good Luck!!
Thanks
Posted on Dec 04, 2009
SOURCE: I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Posted on Dec 30, 2009
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
My proform 345 stops almost every time i get on it. i usually have to let it warm up 10 minutes before it runs ok. whats going on?
1) you must LUBE THIS Happen because the machine has special design for to protect the electronic system. Maybe you have NOW WORN deck belt, time to replace.
2) Lube the rollers bearing too
3) test the bearing for the main motor. and repair
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
Makes grinding noise and belt won't move
If it sounds like metal rotating on metal then it could be a a(roller bearings or b( motor bearings. LUBE INMEDIATELY. + DECK BELT LUBE VERY URGENTE, MAYBE YOU HAVE A WORN DECK TIME TO CHANGE THE BELT.
God bless you
Oct 01, 2012 | Proform 380 Treadmill Walking Belt
Stopping problem
No.
1) LUBE The DECK BELT VERY WELL, see the video and proceed with common sense. this happen because the lack of maintenance according the instr. manual. This happen for to protect the electronic system.Maybe you have worn deck belt, and need replace, but first LUBE.
2) lube THE ROLLERS BEARING too, very well
3) Test the input voltage motor, if there are The motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Sep 06, 2012 | Proform Crosswalk 480 Treadmill Walking...
My machine makes belt gnash noise when i walk on it, like friction sound with the base or platform
1) lube the deck belt very well
2) lube the rollers bearing too
3) lube the bearing from the main motor,+test the pulley+belt for replacement need lubrication go to the repair shop.
4) otherwise you must call some tech for repair.
see the video.
God bless you
Jul 16, 2012 | Proform 380 Treadmill Walking Belt
I hear a frction noice on the belt and the base while runing
1) LUBE the DECK BELT, you have probably a deck worn, by lack of maintenance propely.
2) LUBE the rollers bearing too, very weel
3) test the belt of drive motor, +test the bearing for lube , need repair too, to due the noise, each motor must be LUBE every 12 months aprox depend of use.
4) if you can not do that, call some tech repair.
God bless you
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
How do I best maintain the belt on a Proform 525?
read your manual- there is a small section that states NOT to use silicone/wd-40 on your item. You can use only the lube the manufacture(ICON) reccommends. Sears Parts store or parts on Phone 1-800- FON PARTS your part # is 06-831-135855 it is called walking belt lube The retail store does NOT sell this lube, they do sell the silicone spray-but its for the OLDER treadmills I know this I work on treadmills for the company!!!! with a little work, bypass the retailer, go to the source- they charge less...
Jan 07, 2010 | Proform 525C Treadmill Walking Belt
Exercise & Fitness Logo
157 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
