Question about Panasonic SA-HE70 Receiver
No video Hi, am trying to set up my son't tv, this receiver and his video game machines. We switch the tv to input 2, hook up the game video out and audio out to the receiver inputs and we get sound but no video. What am I missing? The tv is set to channel 4.
  • 97 Answers
Is the video cable composite or s-video? the output from the receiver to the sets line input (1,2,3,s-video) must be the same on most receivers. If the game console uses composite (yellow rca connector) to the receiver, the same cable must be the same from receiver to TV. Some receivers do "up convert" to s-video or to Progressive scan (red,green,blue rca connectors) and do not follow this rule. Yor set needs to be switched to the correct input as well. None of the receivers I have services thus far hve the 75ohm cable lug for RF. Check all the cableing and repost if you find something new or different.
Posted on Jun 09, 2007
I have a pioneer VSX-72TXV receiver, and when I switch to my Apple TV, Radio or DVD the audio does not work, but the video works properly. Also, if I only keep the system on cable TV, the video/audio...
I would check your input settings. If everything is hooked up through hdmi, make sure that those inputs are set for hdmi audio, not digital or analog. If it is a setting problem, you might be able to reset the unit and fix it, but you will lose any settings that you may have had for other things.
Sep 22, 2013 | Pioneer VSX-92TXH Receiver
Have blu ray player and dishnetwork hd receiver hooked up to receiver with hdmi cable. getting picture from both and sound from tv but not thru surround speakers.
Sounds like you have both inputs going into your receiver correctly since you're getting the right picture. Your problem is the output - are the speakers hooked up to the output on your receiver? Is the receiver switched to the right setting? Many receivers have settings so you can switch what inputs are on at the moment. Try looking at the back to see which input they're on and make sure the audio portion of the receiver is switched to this as well.
These are the most common solutions. Hope it helps!
Mar 07, 2011 | Audio Players & Recorders
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Mar 15, 2009 | Yamaha RX-V3800 Receiver
Unable to get ps3 to play when hooked to receiver
The audio inputs on the receiver need to be set to receive the Optical signal on the switch you set the ps3 to. ie Game, DVD, AUX. Each switch needs to be set to receive the audio signal coming into it. Usually on the remotes setup feature.
Feb 10, 2009 | Denon AVR588 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
Nov 29, 2007 | Televison & Video
Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Jul 29, 2007 | Pioneer VSX-406 Receiver
Panasonic SA-HE70 Receiver Logo
56 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
