Question about Pioneer VSX-D710S Receiver
I have second hand Pioneer VSX-D710S ,its remote is universal, remote had no " loudness " button , so how can i open " loudness"
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Pioneer VSX D710S, I hook everything up and turn the unit on, after about 5-10 seconds it flashes POWER OFF and shuts down.
I wouldn't hold my breath waiting for free detailed circuitry.
A precise make and model might yield more-specific answer.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 24, 2011 | Pioneer VSX-D710S Receiver
Pioneer VSX-D710S and the message SP off and DTS off message appear and I have no sound. Any ideas how to turn them back on?
The SP off message is the setting for turning the speakers off while headphones are connected on some Pioneer models. If yours is one such model, hold down the RECEIVER button and press the SPEAKER (text may be written above another main function) button on the remote simultaneously and the sound should return.
Apr 01, 2010 | Pioneer VSX-D710S Receiver
Need remote code to add to universal remote
More info would be good. Do you need codes to use the original pioneer remote to control another componant, or do you need codes for another remote to control the pioneer?
Dec 18, 2009 | Pioneer VSX-D409
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Nov 16, 2007 | Pioneer VSX-305 Receiver
Pioneer VSX-D710S Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
