Question about Video Game Consoles & Games
How do you set a wii console up tothe cello television
4 Suggested Answers
SOURCE: my wii turns on and the television says that there
Make sure you AVI(yellow,red,white)cables are pushed in all the way or you might have it on the wrong channel or you put the AVI cables in a differnt place than last time.
Posted on Feb 15, 2010
  • 174 Answers
SOURCE: I have a nintendo wii console and a xbox 360
Depends on the television, but there are switch boxes now available for composite (Yellow/White/Red), component (Red/Green/Blue), and even HDMI but of course they can't be viewed at the same time.
Posted on Mar 19, 2010
  • 40 Answers
SOURCE: The Wii console could not connect tothe internet.
If your unable to connect to your wireless network
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Don't know how to find your router's password?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
If you're not able to locate the password here, go to your router manufacturers web page and click on support and locate the manual for your router.
    Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
Other suggestions:
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this:
    • Unplug both the modem and the router from the power outlet.
    • Wait a few minutes, and plug the modem back in.
    • Wait a couple of minutes for the modem to initialize, then plug in the router.
    • Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response
  • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. The information you need is found in the "Broadcast Channel:" area.
Posted on Jul 10, 2011
The Wii console could not connect tothe internet. Error code 52030
Other suggestions:
Jul 10, 2011 | Nintendo Wii Console
I dont know if it is my wii but my tv is black and white/grey and white what can i do to repair it?
If your TV is only black and white while playing on the Wii, this is indicative of a problem with either the A/V cable or the A/V ports on your television.
If you have a friend who owns a Wii, try using their cable, or change the A/V jacks to a different set of ports on your television.
NOTE: The A/V jacks are the red, white, and yellow plugs that plugs into your Wii on one end and into your TV on the other. If, for example, these jacks are under VIDEO1 on your TV and you switch the viewing mode to VIDEO1 to play Wii, then try moving them to a set of A/V plugs under VIDEO2. If this is an older TV, there may be only one set of plugs on the TV itself. Try the console on a different TV. It may be time to get a new television. This often happens on older TV's.
May 04, 2011 | Nintendo Wii Console
Bought a new battery pack and charged them to the full but the blue lights are not staying on so i can work the game
You need to sync the remotes tothe wii. open the sd card slot on the front of the wii and press the red button, then press the red button on the remote under the battery cover
Mar 05, 2011 | Nintendo Wii Console
How to hook up netflix
If u can get the internet on wii then go tothe we shop channel. then go to start shopping at the bottom. and go to wii channels. then and netflix should be the first on the top. click netflix. then hit "free 0 points". then hit system settings. and let the mario jump on the blocks for a few. then once its done, go to the wii menu. then u should have netflix.
Jan 08, 2011 | Nintendo Wii Console
My wii was fitted with wasabi dx chip and now nothing on screen
Unplug and then replug the A/V cables into your Wii and television, Make sure your television is set to "A/V" Click on the link below and follow the guide to do this correctly
http://www.nintendo.com/consumer/systems/wii/en_na/setupAV.jsp
Replace the batteries inside the Wii remote control
http://techforums.nintendo.com/nins/board/message?board.id=wii_tech&thread.id=20326
Mar 07, 2010 | Nintendo Wii Console
I have one disc not reading
it has scraches on it happened on mine or its the wii having problems
Feb 18, 2010 | Nintendo Wii Console
Have just tried to connect the wii tothe internet
to connect the wii to the internet you go to wii settings then find internet then there should be connections use connection 2 and set it for wireless then search for your router then input the security code which is on the back of the router which is wpa-psk or wep key then start the search then it ll upgrade then jump back to the wii main menu then you should be able to access the wii s online features
Jan 24, 2010 | Nintendo Wii Console
Wii fit platform does not stay switched on after
you need to play the game and then turn it on when playing
Sep 17, 2009 | Nintendo Wii Fit - Balance Board + Game...
There's something wrong with my wiiremote
what you do is juyst take the wii back tothe store and say i need help and i just don't know what to do with the problem
Apr 23, 2009 | Nintendo Wii Console
Screen won't display
I found your site confusing. If you had read my post, you would have noticed that my problem referred to a 15" flat screen 'CELLO' .TV/DVD combo. I had sound but no picture. When switched on, the screen lit up and the word CELLO appeared then the sreen went black
Nov 25, 2008 | Emerson EWF2004 20" TV
Video Game Consoles & Games Logo
97 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
