Question about TREND Motor Trend Inverter 2400 Watt 400-Watt Power Supply
Motor trend 2400 watt inverter has 147 VAC from both hot and Neut
Motor Trend 2400 watt inverter measures 147 volts from ground terminal to both the hot and neutral. It measures 113.8 between the hot and neutral.Is this normal?? I'm reluctant to plug any expensive equipment into it. Don't want to damage anything.
    President:
  • 948 Answers
Assuming you are testing alternating current and not direct current that sounds quite normal. Plug with confidence. You are using equipment designed for 110v-120v and you're getting 113.8v where it matters most. Higher voltage to ground is nothing unusual, that's just how this inverter is designed.
Posted on Jan 10, 2009
How do you recharge a Motor Trend Jump starter and air compressor
Should have been a patch cord that connects directly to the unit and to 110 volt plug for charging the unit back up. There's a built in convertor that does the re-charge. Find that cord or purchase one from where you got the unit.
Jun 28, 2014 | Power Center Jumpstart 11-411
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Aug 27, 2013 | Hardware & Accessories
How many 100 watt light bulbs can I hook to a 20 amp breaker (120 volts)
A 20 Amp breaker will support 2400 Watts with a 120 Volt line.
120 Volts times 20 Amps (Amperes) = 2400 Watts.
Answer? 24 100Watt light bulbs.
HOWEVER, you should always allow 1 cushion of 100 Watts.
That would be 23 100Watt light bulbs.
(Wait until you add electric motors to the equation. Things start getting a little more complicated)
(I always use 20 amp breakers for lighting. 15 amp breakers for lighting is phased out.
Secondly a 20 amp breaker requires using 12-2 or 12-3 wiring. (12/2, 12/3)
SO does the receptacles.
Therefore 12 gauge wiring is used throughout the house, until you come to the heavier loads )
[ 12/2 = 2 insulated conductors, and one bare copper ground wire.
12/3 = 3 insulated conductors, and one bare copper ground wire.
Remember, with 12/2 the Black wire is ALWAYS the Hot wire. White is Common (Neutral). Bare copper is Ground wire.
12/3 has 3 conducting wires.
One Black, one Red, and one White for the Common. (Neutral) Bare copper is Ground.
Used for 3-way switches ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 30, 2011 | Hammering
Bosch universal mixer 800W. How do I change a 110 volt to a 220 volt? Is it possible?
Bosch is not very good about putting manuals or other documentation online for older products, so I'll have to give you generic advice.
Some electric motors have optional voltage connections. If your motor has this feature, there will be a box or removable plate on the motor with 110 Volt and 220 Volt connections inside. You would need to replace the line cord with a 220 Volt cord having the correct plug for the location you plan to use the mixer, and connect the motor "hot" wire to the 220 V connection in the motor junction box instead of the 110 V connection (the neutral wire goes to the same neutral).
If there is no such option available on the motor, you would also have to replace the motor with a 220 Volt version. Check the labeling on the speed control (inside the mixer) to be sure it is rated for 240 VAC, and check the power label by the power cord. If the label gives a single range of input voltages spanning both 110 VAC and 220 VAC (e.g., "Input 97 V- 265 V") then you only need to change the plug. Unless the electrical parts are all rated for 240 VAC or higher, conversion is not safe.
Some products (especially desktop computers) have a recessed switch on the back that lets you select either 115 VAC or 230 VAC input power. If you have this on the mixer, all you have to do is use a small tool to push it to the other position.
An alternative is to get a 230 VAC - 115 VAC transformer or inverter rated for at least 800 Volt-Amps and wire it with a 230 Volt plug on the primary side and a 115 Volt socket on the secondary side; then you can just plug in your unmodified mixer to this. If you cannot find a box like this, you can buy a "control transformer" from an industrial equipment supplier and put it in a suitable metal box. I recommend including a power switch and a 4 Amp dual-element fuse or breaker on the primary side circuit; you don't want somebody burning up the transformer with a 1200 Watt microwave oven or griddle.
Mar 17, 2011 | Bosch MUM6630 Universal Series Stand Mixer
Tork 1104 is wired 120 vac. hot wire connected to L with jumper wire to 1.hot wire for outdoor lights connected to X. nuetral wires are wire nutted together. not connected to timer. clock not working....
The clock isn't working because the Tork 1104 clock motor requires 240 volts. Jumping the 120 volts over from terminal L to terminal 1 doesn't make it 240 volts. You need another 120 volt leg (180 degrees out of phase) to do that. The Tork 1103 timer is what you need, or change the 1104 clock motor to a 120 volt.
Dec 16, 2010 | Hardware & Accessories
My Motor Trend Inverter 400 watt give's me a fault light upon start up. The fuse is good
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Feb 15, 2010 | TREND Motor Trend Inverter 2400 Watt ...
I have lost one of the screws that hold the wires on and no hardware or lumber yard or auto place carries them. Where can I order one
Try FASTENAL . Should be a store close to you. GOOGLE for a location.. Also, might try a Radio Shack although I have NOT had much there when I was looking for nuts and bolts...
Dec 02, 2009 | TREND Motor Trend Inverter 2400 Watt ...
My fredom 25 inverter is not running the refrigerator in my motor coach when I turn the generator off or unplug from shore power.
Is the inverter rated for more power than the refrigerator draws (watts). Does the coach 12 volt power drop (at the inverter) below 12 volts when the refrigerator comes on? If so, you may need to increase the wire size from the battery to the inverter. Make sure that the voltage doesn't drop at the battery. If so, it may need replacement or a larger capacity battery. When the battery is being charged, measure the voltage at the terminals (which are hopefully clean)--it should be 13.5 to 14.5 volts.
Sep 07, 2009 | Electronics - Others
Xantrex 2412 will not open my Chamberlain Lift Master Prof. door
That must be a pretty big door opener. Problem is probably the motor's starting current draw. Most AC induction motors pull 5 to 7 times their rated running current when starting from a dead stop. (about 7,820 watts) That's much more than the surge capacity of a 2.4 Kw inverter. Sounds like you need a bigger inverter or a smaller door motor.
Jun 06, 2009 | Xantrex Technology Trace Series Inverter /...
TREND Motor Trend Inverter 2400 Watt  400-Watt Power Supply Logo
282 people viewed this question
Top TREND Computers & Internet Experts
Albert Barkley
Albert Barkley
David Semos
David Semos
Are you a TREND Computer and Internet Expert? Answer questions, earn points and help others
