Scanner unreachable. when i start hp deskjet 1050 on windows 7 ulitmate 32 bit for scanning gives error scanner unreachable. Asks to restart. reinstall, wia, ip address error etcdid all but no use. Works well on my laptop win xp.
SOURCE: Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Posted on Jun 24, 2008
my scanner(4200f) dont install canon toolbar in the win vista please help me.thanks
Posted on Apr 12, 2009
TimeDefensiv
  • 746 Answers
SOURCE: 64 bit driver for HP 5470c scanner
Dear go to www.hp.com click on support and drivers then enter your product model now you choose your operating system and download driver free.
First install its software or driver only then you should attach your scanner (when your computer demand or required for its attachment).
Good Luck
Posted on Aug 13, 2009
xptareq2000
  • 1447 Answers
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Posted on Aug 27, 2009
  • 2666 Answers
SOURCE: Window 7 ultimate 32-bit driver for HP Deskjet
See here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01796879
Posted on May 07, 2010
Hp deskjet 920c. will not load to windows 7. 64 bit. it asks for the driver. It appears that I have a 32 bit disk and it requires a 64 bit driver. How do I obtain and download the correct driver?
HP have one of the best after sales services you can get , find the genning HP after sales service on line, enter your product number/model and problem ,its will search for your product and search for problem. then they give download of driver or other bits to be replaced at no cost, and they can or you can download a HP SUPPORT ASSISTANT or you can download first a HP support assistant but make sure it's a genning HP site
good luck
Sep 22, 2016 | HP DeskJet 920c InkJet Printer
After getting Windows 7 I can't use the scanner button on my F340 aqll in one and I can't figureout the scanner feature on Windows 7
It sounds like you installed the generic OS driver from Windows 7. This driver only works for the printer. (Alternatively, you do not have the monitor program running or the destinations set in the HP software.)
If you plugged in the data cable before installing the HP software, uninstall the printer (Devices and Printers) then disconnect the data cable (USB). Go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128309& and select your Win7 version (32- or 64-bit). Then click Next. Expand the section marked driver and download the Full Software. Install the software. Connect the data cable when prompted to do so. (Try a new USB cable since scanning requires bi-directional communication with the printer and can fail when the printer works). Avoid using a USB hub or print server.
If you do have the HP software installed, check that the monitor program is running (Start > Control Panel > System and Security > Adminstrative Tools > Component Services > Services.) The line for the HP monitor should say started. You may need to download and install the patches or the diagnostic utility from the above site to find a specific problem with the Win7 installation.
Next launch the HP software and attempt to scan from the computer. Next use the settings that give good results to program the defaults for the scan destination buttons. Now try to use the scan buttons on the all-in-one.
Once you have the HP drivers for both the printer and the scanner installed, the Windows 7 Fax and Scan and Paint programs should let you successfully scan from the computer. (New scan for fax and scan. File > Import from Camera or Scanner > New Scan for Paint.)
I hope this helps.
Apr 24, 2011 | HP Deskjet F340 All-In-One Printer
My printer( HP Deskjet 1050 all-in-one J410 Series) isnt compatable to my toshiba windows 7 and i lost the cd
I checked it and found that it is compatible with Window 7.
Here is the drivers link for window 7 32bit or window 64 bit.
http://www8.hp.com/us/en/support-drivers.html
click on your printer and then select the operating system and then download HP Deskjet Full Feature Software and Drivers not the Basic Drives.
Note:-To check whether is Win 7 32bit or window 7 64bit
start>>right click on computer>>left click on properties>>now you see whether is 32bit or 64 bit operating system.
Let me know whether this was helpful or not.
Apr 08, 2011 | HP DeskJet F380 All-In-One Printer
Is ther any drivers for deskjet f370 for win7?
According to the HP website there are drivers for both 32 and 63-bit versions of Windows 7.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1128316&
Mar 02, 2011 | Office Equipment & Supplies
I cannot install my hp deskjet 1220c printer in windows 7
Hi. Please check your if you have 32-bit or 64-bit system. Download and install the correct driver from HP. Again, please use 64-bit bit drivers for Windows 7 64-bit.
To check if your system is 32-bit or 64-bit, click "START" then right click "COMPUTER" then select "Properties".
May 01, 2010 | HP DeskJet 1220c InkJet Printer
Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
Feb 04, 2010 | HP Scanjet 5470c Flatbed Scanner
I want the software for printing and scanning software for hp diskjet F2235
Hi
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Problem : Need the Software for HP Deskjet F2210 All-in-One Printer
Operating system : Not mentioned
Solution
Click on the link below to get software compatible drivers with
Following Operating systems
» Microsoft Windows 7 (32-bit)
» Microsoft Windows 7 (64-bit)
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP
» Microsoft Windows XP x64
» Microsoft Windows 2000
» Mac OS X
» Linux
Click on the Following Link
Click on the OS and Download the Drivers
As you work through the article, please note the result of each step, including any error messages you receive. If you require further assistance, please update your case with these details. The more specific the details you provide, the better our ability to resolve the issue quickly.
Cheers
Tejodhar Atreya
tejodhar.atreya@gmail.com
Jan 04, 2010 | HP Deskjet F2210 InkJet Printer
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
245 people viewed this question
jasbo
jasbo
