Question about Kitchen Ranges
I have a GE adora smooth top electric range. When I got home from work last night it looked like it had no power. No clock, light etc. I checked the breaker and it was fine. I started messing with it this morning and I found that if I turn the burner on the display and the light will work but, I don't get any heat at the burner or the oven. When I turn the burner back off it loses power to the display and light again. I tried turning off the breaker, then turning it back on and running the test mode and the oven & broiler click like they are supposed to but, you can only do this with the burner turned on because otherwise there is no power to the display. Any idea what might be going on? I'm lost. Thanks
  • 4 more comments
  • AARON STOWE Nov 30, 2012
    it's the adora series- JBP77MM2BG
  • Richard Roth
    Richard Roth Nov 30, 2012
    That is a control board issue and it will need to be replaced. Here is the part you need to order.http://bit.ly/TwN5Ap
  • AARON STOWE Dec 01, 2012
    That's what I figured. Thanks
  • Richard Roth
    Richard Roth Dec 01, 2012
    Keep me posted
  • AARON STOWE Dec 07, 2012
    That didn't help. I put it in but, it's still doing it and now the clock won't come on when I turn the burner on, like it was doing before.
  • Richard Roth
    Richard Roth Dec 07, 2012
    Something isn't quite right here then. Trace all the wires and see if there is a burnt or shorted wire.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 146 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Posted on Dec 29, 2007
fridgetech
  • 473 Answers
Need to check and see if you are getting 220 volts to the element or if the element is showing resistance with an ohm meter. Any resistance means it is ok. If you are not getting voltage to the elements and resistance is ok then the control board is bad. Note: Always check outlet for proper voltage first! Never know when a breaker has gone bad. Should have 220 volts from line 1 to line 2 and 110 volts from line 1 or line 2 to ground.
Posted on Nov 16, 2007
aborcass
  • 2651 Answers
SOURCE: Our Electric Amana Self Clean Oven, the broiler is
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Posted on Mar 02, 2009
SOURCE: frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
Posted on Mar 12, 2009
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Feb 16, 2014 | General Electric DVM1950SRSS 505 Adora...
Electric range breaker trips at night when all asleep, resets ok
Are you sure nothing else is using power? Sounds like a ground fault to me. Any devices which could cause harmonics which you can think of?
Feb 14, 2013 | Computers & Internet
Top burners light, oven will not gniet
may be a simple glow plug problem, will need more info to determine for sure.
May 09, 2009 | GE Adora JGBP87SEMSS Stainless Steel...
GE JBS55W0J3WW Electric oven will not heat up. None of the 4 elements on the top or the bake or broil elements will power on. The clock, oven light, timer, hot cooktop and oven on lights all power on as...
Check to make sure you have 240v at your receptacle. Lights, clock, timer, will still work with 120v, while the elements need 240v. Start by checking your breakers to make sure that one of the two breakers feeding your oven hasn't tripped.
Apr 13, 2009 | GE JBS55 Electric Kitchen Range
MY BOSCH ELECTRIC RANGE NOTHING WORKS, GET POWER NO HEAT
u may need to set ur clock to manual operation. check instructions if u hav them
Feb 06, 2009 | Bosch HEI7132 Titanium Electric Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Dec 23, 2007 | GE Spectra JBP84 Electric Kitchen Range
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
