Question about OKI C5200n Laser Printer
Oki c5200 printer problem
I changed all of my toner cartridges and now my pictures are all printing red please help me with this problem i have tried to remove and reinsert all of the cartridges but still print all dark red.
  • 97 Answers
Cartridge cross contamination is the problem and expensive to have somebody tear unit down to clean up. If geordie10 is correct, and I think he is, you might look to see if you can replace unit with a used one from ebay or any other source. Your repair bill will not be good if done by a shop.
Posted on Jun 09, 2007
Possibly the cartridges have been put in the wrong place, you need to clean the machine out, as the wrong toners will be on the wrong drums, you may need to replace the drums and get a new transfer belt.
Posted on Jun 07, 2007
SOURCE:
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
How do i clean the print heads on a oki c5200
With the top cover open, gently wipe the LED head(s) with the lens cleaner pad supplied with replacement toner cartridges. A soft, lint-free cloth with some isopropyl alcohol (rubbing alcohol)** can also be used.As the last step before closing the cover when replacing a toner cartridge or an image drum.
If you are experience poor print quality, including
- longitudinal white stripes or fading
- blurred letter edges
CAUTION! Do not use methyl alcohol or other solvents on the LED heads: this will damage the lens surface.
Nov 21, 2011 | OKI C5200n Laser Printer
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
Oki data c5200. When printing color there are streaks where it looks as though something is scraping the toner or page so to speak.
Could be 2 differents problems.
1st you can clean the leds.
2nd you can change the drum of the color problem,
Aug 18, 2010 | OKI C5200n Laser Printer
OKI C5400 & Vista
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
Aug 12, 2008 | OKI C5400 Laser Printer
STREAKS WHEN PRINTING
Thank you. I will go check into this and see if this helps.
Jan 30, 2008 | OKI C5200n Laser Printer
OKI C5200
You wright, it is clutch what is hearing!!! It's on the left side of a printer!!! but when you print an envelope on back of printer you have two lever which must be push up or down!!! It's small picture near!!! You can continue with printing!
Jan 23, 2008 | OKI C5200n Laser Printer
OKI C5200
Just a thought for others... is this an image drum problem?
Also, if you haven't done this yet - try gently shaking the toner cartridges to redistribute the toner. Just make sure you do it gently and over a newspaper or rugs in case some toner spills. One last idea - turn off the printer and turn back on after a few minutes?
Jan 02, 2008 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
175 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
