Just got new hotpoint wmud843p end of rinse cycle bleeps saying check water supply, even thought it has done the wash cycle? any help please
Just plumbed this machine in, did the initial clean, that was fine. then attempted to do a fastwash at 60, wash cycle went fine, then rinse cycle to about 2 mins before the end, read out saying Check supply no water. The fabric conditioner did not go down either. tried turning up the water inlet, pulled machine out to release any kinks pipe, still doing it, done everything the manual said to try with no luck
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
  • 209 Answers
SOURCE: Hotpoint Aquarius WF100 Fabric Cond not rinsing thru & PreWash lite flashing
this sounds like cold water supply not getting to the machine, test the supply from the house is working, is the machine buzzing slightly when it should be filling, if so the fault is the house supply to the washer, if the supply to the washer is fine, check the cold water solenoid for open circuit, thats about all it could be, if it worked fine before, if i have helped rate me please
Posted on Sep 18, 2007
SOURCE: washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Posted on Sep 10, 2008
  • 7 Answers
SOURCE: Miele Novotronic W 844 Washing Machine
Pete,
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Adam
Posted on Nov 24, 2008
  • 100 Answers
SOURCE: Fabric conditioner stays in the dispenser tray
the holes above the fabric softener tray that shower into it may be blocked. use an upturned washing up brush to scrub them with a little fairy liquid and see if that works, it does for me. also could be a water pressure issue.
Posted on Jan 27, 2009
Hotpoint washing machine wf640 there isn't any water coming through when the rinse cycle is on
could be the filter at the water input location in the back of the machine. Or the screen filter at the spigot-end of the input hose....check both hot and cold. First, turn both hot and cold water off at the wall outlet.
Jan 21, 2015 | Hotpoint Washing Machines
Washing machine bleeping when door is closed
Check your water supply isn't kinked or blocked and check filter, clean if necessary. Red.
Apr 05, 2014 | Hotpoint Washing Machines
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Mar 05, 2012 | Hotpoint Washing Machines
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Suds remain after full cycle
I would personally look at a cold water supply problem, since cold water is what's used in the rinse cycle. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlets. (especially on the cold water side). Make sure they are clear of rust or debris. Check the solenoids at the inlet valve. Use a multimeter or ohmmeter to test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. It could be a detergent or even a pump issue, but I would check the cold water supply first. Hope this helps and best wishes.
Aug 20, 2009 | Washing Machines
Hotpoint washer Won't rinse
your cold water valve will be your problem or you've turned the water supply off, if the supply is not off put the machine on to the final rinse if it fills it will be the main rinse valve gone. The cold water valve is a double one with 2 solaniods. Unplug the machine turn water supply off remove fill hose there are 2 screws keeping the top on, remove them lift the lid off.undo the screws that keep the valve on, take note wiring and remove pull the black hoses off, replace with new one. The resistance of the valve will be around 3.4 kohms
Oct 07, 2007 | Washing Machines
Sep 18, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Zanussi Washing Machine
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
