Question about Solar Welding Tools
I have a solar 2-125 wire feed welder left to me by my husband. Trying to sell it - potential buyer wants to know amperage and I need to know about how much it is worth. It is probable over 10 yrs. old and is in fair condition
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
SOURCE: NO WIRE FEED BUT WELDER CLICKING AS IF FEEDING
This could be caused by not enough pressure on the drive wheel. Try adjusting pressure as spelled out in you manual.
Posted on Apr 10, 2009
  • 71 Answers
SOURCE: I have a solar meg welder 2-175.The feed motor for
try changing the fuse if it has one
Posted on Aug 08, 2009
SOURCE: What is a Solar 2-175 mig welder worth?
I don't know what are you asking for it and where are you located jamercer1975yahoo
Posted on Oct 10, 2009
luxur4
  • 92 Answers
SOURCE: solar welder 2175 wire keeps feeding wont stop
Look on the front pannel. thier should be a "latching Switch" indicated by "4 X 2" little arrowes. The 4 is " pull the triger -- the release the arc continues, the "2" is pull the trigger and the arc startes release the trigger the arc stops simplesssssssss
Ken
Posted on Jan 26, 2010
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
Century wire feed welder
Sounds like you need to learn to weld
or Metal is way rusty or bad Ground or Amperage too high
Nov 16, 2013 | Welding Tools
Have a solar 2160 wire feed welder but do not seem to have any heat control.can't weld sheet metal,just way to hot.
The capacitor(s) may be open. or resistor has failed. It is also possible heat selector is fused to the one setting.
Nov 20, 2012 | Welding Tools
Hello, I would like to purchase 3035 spool gun and attach it to my self made welder. Could somebody to tell me which power supply I have to provide for spool gun motor? DC voltage, amperage ? Can I use...
the spool gun is a 12volt motor, i usely hook it to the power feed for the feed motor in the welder. it is also 12 volt . i have heard of some welders that have 110 volt feed motors but have not seen one yet but just to be save i would test the power feed to the feed motor before i made the connection.
Mar 11, 2011 | Hobart Handler 210 Wire Feed MIG Welder
Wire feed does not stop. Not the trigger.
Ck the feed roller contact relay
Jun 02, 2009 | Welding Tools
A consumer grade machine. Nowhere near a miller or lincoln How much are you wanting to get?
May 19, 2009 | Welding Tools
Welding Tools Logo
50 people viewed this question
Top Solar Welding Tools Experts
Bill Boyd
Are you a Solar Welding Tool Expert? Answer questions, earn points and help others
