Question about HP 418446-001 - HP Special Edition L2000 Series Full Featured Laptop Systemboard for
Keyboard is stuck and need change boot order
HP L2000 laptop keyboard is stuck and need to change boot order.
I need to change boot order from hard drive to CD.
    President:
  • 948 Answers
You can try connecting an external keyboard. When the external is connected the BIOS may ignore in built-in keyboard, bypassing your keyboard error.
You can also try removing the stuck key by prying it up GENTLY.
The answer to your question is unless you can get a working keyboard connected to your computer there is no way to change the boot order. Without a working keyboard you can't get into the system setup (BIOS), nor can you press the correct key.
Posted on Jan 10, 2009
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
I have a hp special edition L2000. Power is getting to the computer as the LED lights come on and then continuously blink. I can feel the cdrom running in a start and stop pattern, much like the blinking...
try to recover first your data, remove hard disk and make it slave to other station. copy all your files. then you may now reformat using a fresh install of windows xp.
Apr 13, 2010 | HP Special Edition L2000 LiveStrong Mobile...
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
How to reformat a laptop
since u didnt specify te model or brand 'm giving u all the option
1) if u have the recovery cd of the laptop then put the 1st disk and boot from it and follw the prompts
2) now if u dont have the Recovery disk then put theoperating system cd and boot from it and follow the prompts.
if u are following the 2nd step then u shud have all the drivers for the laptop for the os downloaded before doing the formating.
note: to all these first u shud go to bios and change the boot order to CD drive as priority 1 and local hard disk as priority 2
Aug 09, 2009 | HP Pavilion dv7 Keyboard (483275-001)
Keyboard and Mouse stuck on startUp
Check that the keyboard & mouse are plugged in completly. Try unplugging then, then re plugging again. You can also try using a different keyboard & mouse.
Jun 15, 2009 | HP 418446-001 - HP Special Edition L2000...
Change boot sequence for HP L2000
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Fixya!
Chris (ziraffa)
Jan 10, 2009 | HP 418446-001 - HP Special Edition L2000...
HP ZE2000
Dust on the CPU Fan, or rear casing Fan. Or Hard-Drive wear to fluid bearings.
Mike @ compurepair.
Jul 08, 2008 | HP Pavilion ze2000 Notebook
Compaq laptop/no boot up
Initially it may be suspected that your laptop is detecting a hardware problem, probably the hard disk. Since it partially boots and there is display, the following can be ruled out: video card, memory and display systems. That would leave us the hard disk and the motherboard left. If the motherboard is in question, chances are it is the BIOS.
Pls try and verify that the hard disk is connected snugly. The hard drive is usually inside one of the slots covered by a panel/lid held by a single screw.
If your concern has not been corrected after completion of the above procedures, further diagnosis may be required.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | HP Compaq Presario V2000 Notebook
HP 418446-001 - HP Special Edition L2000 Series Full Featured Laptop Systemboard for Logo
495 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
