Question about RCA Lyra RD2011 MP3 Player
Blank screen and won't play music
My screen is blank when you turn it on, I have tried changing batteries a bunch of times and it still does not work. And now because the screen will not display I can not tell what I am selecting, and because of that it is now stuck on Radio and will not go back to my music.
4 Suggested Answers
  • 130 Answers
SOURCE: my mp3 player wont turn on
I suggest you might need to clean up the cantacts of the buttery poles from corrosion or it could be they are broken or out of place
Posted on Feb 12, 2006
  • 150 Answers
Good Day, FAT (not fat like you think, FAT means File Allocation Table). That means its corrupted, can be fixed by formatiing. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Posted on Sep 17, 2007
  • 8596 Answers
SOURCE: RCA OPAL M4008 screen is blank and now it won't come on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 29, 2008
SOURCE: RCA Opal M4202 won't turn on
go on to and download the firmware
Posted on Apr 05, 2009
0 characters
1 Points
My mp3 player turns on but goes blank as soon as the music comes on.
Change the backlight settings in the Settings menu of the GoGear if the music continues to play when the screen goes dark.
Otherwise, if the music also goes off when the screen goes blank, run a Repair in the Philips Device Manager.
Mar 31, 2009 | Philips GoGear SA3125/37 MP3 Player
Blank screen
Typically this is an indication that your battery is dead. If the music is still playing but the screen is blank I would say a hardware failure and replacement would be the best option.
Jan 06, 2009 | SanDisk Sansa m240 MP3 Player
I pods Nano blank screen
You may reset or restore your iPod for a try, this way can fix many common iPod problems.
Or go to the iPod setting, turn off the "Enable TV out"
If you don't know how to put DVD movie on iPod, I think this step by step guide would help you
If you have any other questions, feel free to email me.
Aug 18, 2008 | Apple iPod nano
Nano goes blank
Reboot your Ipod by holding down on the center button while holding down on the menu button.
This should reboot your IPod.
If that doesn't work plug your Ipod into Itunes and restore your software back to factory settings. Make sure that battery if fully charged as well.
Jul 17, 2008 | Apple iPod nano
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Try the Five R's suggested by your user's manual - you can get the manual from Apple's website if you have lost it:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Jun 14, 2008 | Apple iPod nano 2nd Generation MP3 Player
Go throught this page
Your ipod might need to be repaired, the apple service assistant is on the bottom.
Might be a loose connection or other failing component I don't think there is no quick fix for this.
If the problem is solved dont forget to rate as fixya otherwise there is no need to rate it. As there is noting else we could do about it.
May 15, 2008 | Apple iPod nano
Blank Screen-Archos Jukebox
Frank, have you tried changing the recharchable batteries?
Nov 16, 2007 | Archos Jukebox Studio MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
RCA Lyra RD2011 MP3 Player Logo
16 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
