I have an HP Compaq PC CQ5300Y and the rocketfish 3.5" sata is connected but when I hit backup is not showing me anything why?? But yet if I plug anything on the usb it show it why?
    Problem Solver:
  • 6 Answers
I use an online PC back up service.It is automatic and will back up your files periodically. You can back up all your photos, music and data for free here, http://goo.gl/3VahX
Posted on Feb 08, 2013
benwabnick
  • 2404 Answers
SOURCE: warning u must plug magicJack in usb
Courtesy of the MagicJack website, try these steps located here to resolve the problem:
http://www.magicjacksupport.com/warning-you-must-plug-magicjack-into-usb-t3208.html
Its the first message that is closest to the top of the page that gives you the instructions.
Posted on Feb 09, 2009
LRL Computer
  • 64 Answers
SOURCE: sata hdd not detected.
Check the bios to see if it made the pata drive primary. If it did the system will try to boot off of your backup drive and you could think that it is not seeing your sata drive. If that is the problem you must go into the drive configuration and make the sata primary.
Posted on Nov 22, 2007
  • 101 Answers
SOURCE: My HP Compaq nx5000 is not starting. So I have
Due to the nature of the problem you describe, it appears that you could be experiencing an issue with the hard drive and/or the external USB case. Below I have listed 2 possible solutions to help resolve your issue.
A. External USB Case 3rd-party Driver
USB cases (depending on manufacturer and/or OS) will sometimes require a device driver to be loaded before the device (in this case, an external hard drive) will function at its maximum potential. From Windows XP and on, this has not been the case as the OS will provide its own driver but if you are using an older OS, this maybe required. If the external case brought a driver CD, perhaps installing could shorten the time to access your data on the drive.
B. Hard Drive Corruption/Failing
When a hard drive has become corrupt or is failing, the device tends to become sluggish and overtime completely unresponsive. When this occurs, the best solution is to backup your data as soon as possible and replace the failing hard drive before it dies completely and you cannot retrieve your data.
This is a common scenario and unfortunately, due to the manufacturing process of hard drives, the inevitable end to all hard drives once they have met their end of life.
SSD (Solid State Drives) are hard drives that are not manufacturer using metal platters but rather flash memory (such as that of USB flash drives, digital camera memory and cellular phones). These drives feature no moving parts, hence their failure rate is extremely low. Also, their lifespan is typically rated for tens of years with some industrial products rated with lifetime warranties and are able to withstand drops, falls and extremely low/high temperatures.
The trade off on HDD vs SSD is the cost, with HDD prices hovering around $.30-.50 per GB while SSD prices (while falling) are still around $1-4 per GB.
Posted on Aug 11, 2010
  • 17 Answers
SOURCE: Compaq Presario F730US PC Notebook: i installed hp wireless assistant. but when i open...
I used to have internet wireless connection problems and finally realized that F761usa front wirless swich was changed frequently, even I believe I never touch there.
Posted on Sep 14, 2010
davidmamian
  • 543 Answers
SOURCE: Compaq Presario F761US Notebook PC no wifi cannot
Go to HP.com, support and services page
Posted on May 29, 2011
1796 sata cabling error
Make sure your Sata connection start from Sata 0 and on up. You'll get the 1796 error when you have sata drives or devices plugged in other sata connections, Like: Your first Hard drive in sata 0 your second drive in sata 1 your optic drive in sata 2....You system (BIOS) will automatically start at sata 0 then sata 1 and so fourth.
hope this helps ya and thank you for using FixYa.
Nov 04, 2013 | HP Compaq dc7600 Convertible Minitower PC...
Have a d530c tower how do you add a sata drive?
Hi richo64
It seems your motherboard is not equiped with Sata plots :
http://h18000.www1.hp.com/products/quickspecs/11632_na/11632_na.HTML.
If this is the case , you need to purchase a PCI Sata controller card with at least one internal Sata plot .
Disconnect power plug and make sure you are not static electrically loaded . Open tower by removing side panel . Install PCI card on an available PCI plot inside your tower . You will also need to acquire a Molex/Sata converting power cable and a Sata interface cable . Once done , install your Sata drive in an available place in your desktop and connect the cables .
Start your pc . If you have kept the old Pata drive in operation , immediatelly and repeatedly hit a F key ( often Fi or F3 or F8 , it depends on the machine ) to acces bios , select the Sata drive and fix the boot priorities .
Sata controller cards and cables are easy to find by googleling on the net or in any computer shop .
Best regards ,
fanaudi .
Jul 23, 2011 | HP Compaq d530c PC Desktop
Wish to change the HD for HP D5100 SFF
For Changing the HD do the following
1. Take the Backup of all the required file from the HDD to DVD or tapes
2. Shut down the system
3. Remove the power cables first
4. Remove the side cover of the CPU
5. Carefully remove the HDD Power connector and IDE Cable or Sata Cable
6. Un Screw the HDD Screws
7. Remove the HDD Carefully
8. Place the New HDD and Screw it carefully.
9. Plug the Power Connector of the HDD and IDE Cable or Sata Cable
10. Plug the Power cable and check that the HDD Is detected.
11. If detected install the O/S as required by you
12. If not detected check the HDD Power connector and IDE Cable or Sata Cable
Let me know that i Fixya! the problem
Thanking you.
Nov 27, 2010 | HP Compaq dc5100 PC Desktop
HP Compaq 7300. Tried to load Windows XP but before installation cannot see HDD, yet in BIOS one can do HDD integrity check and akk ok. Where is the problem?
You need to format first. If install cannot see drive, drive maybe faulty, or need an F6 driver SATA.
www.custompcblog.com/.../installing-windows-xp-sata-hard-drive
Check out link above.
If you cannot, format and "See" the drive, then it is most likely faulty. To test you must get a SATA/IDE USB Dongle, they are a few dollars. Connect uo the harddrive you have taken out of the laptop, and connect up via the USB poet, on another PC. IF it installs and shows up, then the problem may lay with your laptop, however, at this point, if you want, and drive is blank or you don't want anything on the drive, use Windows, and Format the drive, NTFS, now. Then take it back to laptop and try to reinstall. IF it STILL will not "See" the drive, then the laptop is definitely faulty. if it does, continue on and install Windows. Remember to set BIOS to Boot from DVD first. and set back, at finish of install.
Mar 28, 2010 | HP Compaq nx7300 Notebook
ESATA hard drive enclosre difficulties
If you are sure the connections between the external case and the hd inside are good then the hd itself is dead, nothing you can do but junk it.
Jan 12, 2010 | Computers & Internet
There is something pluged in wrong in my Compaq Presario SR5130NX tower and i need a picture showing how to plug in all the drives to the motherbord
If its an IDE cable (Flat wide one) ensure the last drive (Operating system) one is plugged in here set to MASTER, with the slave drive connected along this ribbon set to SLAVE.
If SATA cable usually narrow and red plug into any SATA port on the mobo, doesnt matter which order.
Dec 21, 2009 | HP Compaq Presario SR5130NX PC Desktop
SATA 2.5 connectors different than current Presario R4000 laptop
It seems that your notebook does not have sata connection to Hard drive. Your harddrive is IDE connection. Sorry but you can't use SATA on this laptop.
Oct 22, 2009 | HP Compaq Presario R4000 Notebook
Connected a 1 TB harddrive to one of the sata connectors,but in doesn't show up in disk managment to format
Two things, first on a desktop, make sure the other sata connectors are enabled. Most desktops do not come with the sata inputs enabled, this can be done through the bios. Just hit F2 during the post phase and when the HP splash screen shows. Once there look for the SATA settings.
secondly, if the hard drive has never been installed on a computer it most likely is not "initialized", this has to be done for the hard drive to be seen, formatted etc. on the computer. Western Digital and Seagate have their own software that does this process. Since you cannot "see" the hard drive in the computer you have installed it in, I would guess that the sata connectors are not enabled.
Oct 14, 2009 | HP Compaq Presario SR1300NX (PP195AA) PC...
HP d530 PC - SATA Harddisk - Chassis does not close any more
Martin,
They make SATA cables with a 90 degree connection on one end.
Hopefully this will solve your clearance problems with your case.
Here is a link to website that carries these.
Website Link
They work great and fit tight against the drive.
Hope this helps,
Eric
Jan 18, 2009 | HP Compaq d530 PC Desktop
Does my d530 CMT have a SATA connector?
Answers to your questions:
1. Yes
2. Very likely
3. a Google search should show you what the connectors look like.
4 HP/Compaq do a good job of providing documentation. Go to hp.com and put in your system information. You should be able to locate motherboard diagrams there. If you can't let me know and I'll try to locate them.
Dec 29, 2008 | HP Compaq d530 PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
